Science-Backed Standards Keep You Safer in the Skies
Rigorous tests for all aspects of multidimensional images
M. King/NIST
NIST researcher Jack Glover holds a test object for millimeter-wave imaging systems—scanners that are used to check passengers in many airport security lines.
Megan King
Thu, 01/15/2026 - 12:03
If you’ve flown in the U.S. in recent years, you’re probably familiar with the airport security experience of entering a booth, raising your hands above your head, and having a machine check your body. That machine is called a millimeter wave scanner.
I’ve done this many times and never given it much thought. But National Institute of Standards and Technology (NIST) researcher Jack Glover sure has. He’s a physics expert who works to make sure the Transportation Security Administration (TSA) can test those machines effectively.
This work has saved the government hundreds of millions of dollars and, more important, kept millions of passengers and flight crew members safe in the air.
So how do you keep those machines working properly? As with most things at NIST, it all comes back to measurement and standards.
When you step into the airport scanner, the machine uses millimeter waves to capture an image of you. Millimeter waves transmit through clothing but reflect from skin, making them well-suited to this task. An algorithm looks at each image and flags anything that’s not a human body part for further screening by the TSA agents. (That’s why you must take everything out of your pockets.)
What’s a millimeter wave?
Millimeter waves are electromagnetic waves, just like visible light, radio waves, Wi-Fi signals, or even X-rays. They have wavelengths that are measured in millimeters (or even up to an inch). This wavelength is much longer than that of visible light, but much shorter than that of Wi-Fi or radio waves.
The TSA needed an image quality standard to ensure that the scanners at every airport consistently delivered high-quality images to the algorithm.
Glover explains that the process started by convening experts to discuss what characteristics of an image are most important for detecting threats. The group included experts from the U.S. Department of Homeland Security (DHS), universities, equipment manufacturing companies, and other organizations.
One of the challenges of this process is the variety of data that the millimeter wave scanner produces, including both 2D and 3D images. So, the experts had to work toward a standard that rigorously tested all aspects of the multidimensional images.
“While there are many established test methods for X-rays, there was nothing for millimeter waves,” Glover says. “So, we applied our knowledge from X-ray physics to make completely new tests.”
The millimeter wave standard’s effect
The TSA uses the standard—called a technical performance standard—in extensive lab testing and plans to test it directly in airports. Glover explained that one of the standard’s most important uses is testing new machines or parts that are swapped out in existing equipment.
An example of this scenario would be if a supplier needs to swap out a part when a particular model of antenna is no longer available. This has happened more in recent years with various supply chain disruptions. The TSA won’t just take the supplier’s word that the new radar antenna works just as well as the old one. Experts must check that new part themselves.
Before this new standard was created, TSA explosives experts had to spend time and resources testing machines with real and simulated explosives in DHS laboratories. These materials are dangerous and must be handled with extreme care.
Now, the TSA can rely less on these tests by ensuring that the technical imaging performance hasn’t changed, resulting in time and cost savings.
Glover’s expertise in physics helps ensure that airport security machines are tested effectively. Credit: M. King/NIST
Beyond the millimeter wave
This is just one of many joint projects NIST has worked on with the TSA and DHS standards branch at the Science and Technology Directorate. For more than 20 years, NIST experts have used their deep knowledge of physics, measurement science, and standards to keep people safe while traveling. With financial support from the DHS, Glover and his colleagues have contributed to standards for systems that screen people, cargo, vehicles, luggage, and more.
Glover said he loves the research because of the opportunity to solve problems and help people.
“In this work, we are tasked to solve specific, existing problems that stakeholders have highlighted, so we know those same stakeholders will use our research,” he says. “In this case of the security screening standards, I know they’re being used because I get questions and comments almost every week from all over the world.”
Traveling as a millimeter wave expert
After learning about Glover’s work, I asked him about his typical travel experience, given that he devotes so much of his time to keeping us safer in the skies. While others may dread the security line, does he look forward to it?
“I like to observe what’s happening. What machines are they using? What’s scanning the bags? It’s all fascinating because it’s my work in action in the real world,” he says.
Published Nov. 19, 2025, in NIST’s Taking Measure blog.
Submitted by dangermoney on Thu, 01/15/2026 - 11:38
How to be efficiently wasteful
It's cute that Mr Glover likes to nerd out while everyone's civil liberties get violated, but it would save even more time and money if we got rid of the intrusive security theatre altogether. TSA has never once caught a terrorist, but they've stolen plenty of iPads, groped your grandma, and blown an awful lot of my money on fancy gadgets like this.
Up next on Quality Digest: How to maximise the OEE of a convenience store card skimmer.
About text formats
