Lasers and Math Can Help Doctors Deliver Just the Right Amount of Medicine
Specialized mathematical techniques help NIST team go with the flow
Henry Nonnemaker/NIST
Knowing how fast medicine flows is crucial to delivering the right amount. Summer Undergraduate Research Fellow (SURF) intern Henry Nonnemaker used specialized math techniques to help better understand fluid flow.
Henry Nonnemaker
NIST
Wed, 09/16/2026 - 12:03
When doctors need to deliver precise doses of medicine on a strict schedule, they often administer it intravenously. Intravenous drug delivery methods need to carefully control the flow of medicine into a patient. Knowing the medicine’s flow rate—or the volume of fluid flowing into the patient each second or minute—is crucial to delivering the right amount of medicine at the right time.
Surprisingly, the correct amount is sometimes not very much at all. Imagine a 1 L bottle divided up into a billion parts. One of those parts is a nanoliter.
Doctors may only need a handful of nanoliters of fluid to flow each minute.
Fluid flowing at the rate of one nanoliter per minute, in the words of NIST biomedical engineer and specialist in ultratiny technology Greg Cooksey, is like “draining a can of Coke through a hair if it were a straw, over about 700 years.”
Cooksey works to improve how we measure these super-slow flow rates. Currently, the devices we use to measure flow rate, called “flowmeters,” can be slow, fickle, or imprecise when used on nanoliter-per-minute flows.
Run It Past the Murder Board
Submitted by dangermoney on Wed, 09/16/2026 - 13:01
Where's the beef?
The author "developed a simulation using specialized mathematical techniques," but that's curiously all the detail we're allowed to have; I think the subheading of this article teases a little more than that.
If it's a finite difference method to numerically integrate the partial differential equations describing multicomponent mass transfer in laminar flow, you can just say so. I won't tell anyone.
