A problem shows up, and the fix usually arrives five minutes later.
“We need more training.”
“We need a better system.”
“We need another person.”
“We need a new checklist.”
Sometimes one of those answers is exactly right. Too often it’s not. The organization has named a solution before even agreeing on what failed.
Anyone who works around quality knows the tools: root cause, process variation, corrective action, verification. The problem isn’t that organizations have never heard of them. The problem is that pressure makes people skip diagnosis. A late order becomes a scheduling problem. A defect becomes an operator problem. A missed handoff becomes a training problem. A bad audit result becomes a documentation problem.
Then time and money get spent fixing the label instead of the failure.
Why we jump to the fix
Action is easier to defend than diagnosis.
A leader can approve software. A manager can schedule training. A team can add a form. Those things are visible. They can be put on a project plan and reported as progress. Saying, “We are still figuring out what is actually failing,” is a harder message when a customer is angry or a metric is red.
That doesn’t make fast action wrong. It means the order matters. If the problem is poorly defined, fast action can turn into fast rework.
You see versions of this everywhere:
• Defects rise, so operators get retrained. The real issue is a measurement method that produces different results between shifts.
• Delivery dates slip, so the company buys scheduling software. The real delay is an approval step that holds work for two days before production ever sees it.
• A service queue grows, so more people are added. The real problem is that incomplete cases are being returned and entering the queue twice.
• An audit finding leads to another checklist. The checklist catches the issue, but nobody has clear authority to close the exception.
The first fix in each example might still help. It just isn’t fixing the problem the organization thinks it’s fixing.
What this looked like in one consulting engagement
One organization I worked with believed its problem was outreach. It wasn’t reaching enough people, so the obvious answer was more advertising and more promotion. The problem was that we couldn’t actually test that theory. Products and activities weren’t consistently tracked at the SKU or process level, ownership was unclear, core work rotated among people, and there were no reliable checks or gates. We had an advertising diagnosis before we had an operating system capable of telling us whether advertising was the problem.
Once we put clear owners, trackable categories, checkpoints, and review gates in place, the situation became measurable. If one person was creating the breakdown, we could isolate it. If one process or product was underperforming, we could see it. And if outreach really was the issue, we could prove that, too. The first corrective action wasn’t “buy more advertising.” It was to make the operation visible enough to know which problem deserved a fix.
Define the failure before you prescribe the answer
Before anybody says training, software, head count, or new procedure, make the team describe the failure in one plain sentence.
Not: “Our quality is slipping.”
Not: “People aren’t following the process.”
Not: “We have a training issue.”
Those are conclusions; a useful problem statement says what can actually be observed.
For example: “Final inspection rejects on Line 2 increased from 2.1% to 5.8% during the last six weeks, with most failures occurring on the same dimensional characteristic.”
Now there is something to work with. At minimum, the team should be able to answer four questions: What’s happening? Where is it happening? When or how often does it happen? What should be happening instead?
If those answers are still fuzzy, it’s probably too early to pick the countermeasure.
That’s where basic root-cause tools help. The Five Whys can push a team past the first convenient answer by asking what caused each layer of the failure; a fishbone diagram can force the team to look across categories such as people, methods, machines, materials, measurement, and environment instead of blaming the first visible symptom. The point isn’t to use every tool on every problem. It’s to use enough structure to test the cause before spending money on the fix.
Four checks before choosing the fix
Once the failure is clear, I use four checks before deciding what kind of fix even makes sense.
1. Is the standard clear?
Sometimes people aren’t following the process because there’s no usable standard to follow. The work instruction might be outdated, contradictory, buried, or written for a different version of the process. Training people harder on an unclear standard just spreads the confusion.
2. Can the process actually be executed as designed?
A process can look fine on paper and still be impossible in real work. The required tool could be unavailable. The data may arrive too late. One role might depend on an approval it can’t get quickly enough. The expected cycle time may not match the capacity of the process. If the process itself is broken, telling people to “follow the process” isn’t corrective action.
3. Does the system make the right behavior easy or hard?
If the correct path takes three workarounds, and the wrong path takes one click, the organization has designed a predictable failure. Software, forms, automation, visual controls, or workflow changes may be the right answer here. But they should follow the diagnosis, not replace it.
4. Is there actually a capability gap?
Training makes sense when people don’t know how to perform the work, make the judgment, use the tool, or recognize the condition. It doesn’t fix missing capacity, late information, bad process design, or lack of authority. If an experienced employee knows exactly what to do, but the system will not let the person do it, another training session is just activity.
Containment isn’t correction
Sometimes you have to act immediately. Fine. Do it.
A customer issue may be active. A safety concern may need control now. A defect may require 100% inspection while the cause is still being investigated. That’s normal containment.
The mistake is letting the temporary action quietly become the permanent fix.
Extra inspection can protect the customer. It doesn’t mean the process improved. A second approver can reduce short-term risk. It doesn’t mean the original decision process is reliable.
Label the action honestly: “This contains the problem while we determine the cause.” That one sentence prevents a lot of fake closure.
Test the cause before you scale the fix
Once you have a credible cause, don’t launch a 12-month program if a one-week test can tell you whether you are right.
If a confusing inspection instruction appears to be driving variation, rewrite it for one area and test it. If a missing data field is creating rework, make the field mandatory for a pilot group. If a calibration interval looks like it’s contributing to drift, test a tighter interval on the affected equipment before redesigning the whole maintenance program.
The point is simple: Change the suspected cause and see whether the result changes.
This is where a lot of improvement work goes sideways. Teams track whether the solution was installed instead of whether the failure changed.
Training attendance isn’t proof that defects went down.
A software go-live isn’t proof that cycle time improved.
A new form isn’t proof that errors stopped.
The fix must earn its place by changing the outcome.
The 5-minute check
Before approving the next training program, software purchase, staffing request, checklist, or procedure change, ask five questions:
• What exactly is failing?
• What evidence tells us that?
• What do we believe is causing it?
• Why does this proposed action address that cause?
• What result will tell us whether it worked?
If the team can answer those five questions clearly, move. If it can’t, another hour of diagnosis may be cheaper than another month of fixing the wrong thing.
This isn’t an argument in favor of slower decisions. It’s an argument against spending money before you know what you’re buying your way out of. Diagnose first. Contain what has to be contained. Test the cause. Then scale the fix that actually changes the result.
The point about naming a…
The point about naming a solution before agreeing on what failed maps cleanly onto supplier 8Ds we review.
The reports customers bounce most often already have a fix in D5/D6 — retraining, a new checklist, or 100% inspection — while D2 still restates the complaint and D4 never separates occurrence from escape. Containment is left running as if it were the permanent correction, exactly the “fake closure” risk you describe.
A practical gate before picking the countermeasure: write one observable failure sentence (what, where, when/how many, vs. what should happen), then ask which control should have caught it and why it didn’t. If that escape path isn’t evidenced, it is too early to buy training, software, or head count.
Free 8D/D4 checklist (advisory, no invented evidence): https://8d-gate.vercel.app/?utm_source=qualitydigest&utm_medium=comment&utm_campaign=dont-buy-fix#email-capture
Disclosure: we built 8D Gate, a free advisory pre-send check for 8D reports.
