A more detailed look into contributing factors
Amari Shutters / Unsplash
Bruce Hamilton
Wed, 09/02/2026 - 12:03
In my last post, I reflected on a couple of different whys to interrogate a process—either to solve a problem or to create a process improvement. Here are a few more contextual uses of the question “Why?” that I’ve found very helpful as a manager and improvement leader.
Purpose expansion
When asking why five times to solve a specific problem, we’re intentionally drilling down into the problem to find a root cause. Shigeo Shingo flipped the scale with purpose expansion to encourage us to think of every end as a means to a higher purpose. For example, if 5S is a means to a higher purpose (reduced searching for tools), then reduced searching (motion waste) must also be a means to a higher purpose.
Submitted by dangermoney on Wed, 09/02/2026 - 09:31
(No subject)
Submitted by Law (not verified) on Thu, 09/10/2026 - 00:23
Answers to WHY question.
Your techniques 5 Whys is depend on how good your answer to the frist question. If your answer is wrong or not accrate, it will be pointless to answer the second Why question to your first answer. Asking and using why questioning is not good enough if you can have the first answer correct or accurate. This is a main tipping point.
