When Infrastructure Problems Become Energy Assets
A TRIZ perspective on heat-waste reuse
VividScene303/iStock
Akhilesh Gulati
PIVOT Management Consultants
Mon, 02/23/2026 - 12:03
In the world of quality and lean, waste is the enemy. We hunt for it in cycle times, inventory buffers, and defects. But occasionally we encounter a form of waste so massive and literal that we fail to see it as a resource.
A recent redevelopment project at Denver’s National Western Center (NWC) offers a master class in pivoting from a compliance mindset to a value-creation mindset. The project faced a classic infrastructure bottleneck: two massive, 72 in. wastewater mains running through the heart of the site. Because the effluent within the mains needed to dissipate heat before discharge, building over them was a regulatory and engineering nonstarter.
Conventional thinking would frame this as a problem to be mitigated. Instead, the engineering team reframed it as a resource. By capturing the waste heat from the wastewater flow, the project now uses the sewer system to heat and cool major portions of the campus.
To the traditional eye, these pipes were a constraint. To the TRIZ-trained eye, they were a thermal battery.
The lean pivot: Turning harm into benefit
In a standard lean value-stream map, these pipes represented muda (waste). The heat was a byproduct that stalled urban redevelopment. However, using the lens of TRIZ, this solution exemplifies a powerful shift: turning a harmful factor into a beneficial function.
TRIZ, a Russian acronym for “theory of inventive problem solving,” is a systematic framework for solving technical contradictions without compromise. Rather than “meeting in the middle,” TRIZ uses 40 inventive principles to bypass trade-offs (such as increasing power without increasing weight). By mapping problems to a “contradiction matrix,” practitioners can identify proven strategies (like “blessing in disguise” or “self-service”) to turn system constraints into competitive advantages. Developed by Genrich Altshuller after analyzing thousands of patents, TRIZ provides a systematic framework for innovation.
Instead of spending capital to move the pipes, the team at NWC integrated a heat recovery system. It pulls thermal energy from the raw sewage—which stays at a consistent temperature year-round—to provide low-carbon heating and cooling.
The project leveraged what already existed:
• A continuous flow of wastewater
• Predictable thermal energy
• Proximity to buildings with high energy demand
Thus, the sewer line became multifunctional, serving as both waste transport and a utility provider. This reduced emissions and avoided the capital cost of redundant heating equipment.
Solving the contradiction
To a quality professional, this is a win because it resolves a technical contradiction. In any system, when we try to improve one factor (like energy efficiency), another factor usually gets worse (like the complexity or cost of the equipment).
The NWC team bypassed this trade-off by applying four specific inventive strategies.
Extraction: They “took out” the disturbing property (heat) from the pipe so it could fulfill its primary role without interference.
Self-service: They used a waste resource to perform a new, useful function, allowing the system to maintain itself.
Blessing in disguise: They took the very characteristic that made the pipes problematic—excess heat—and made it the foundation of a new energy solution.
Universality: They tasked a single component (the infrastructure) with multiple roles, increasing the “functional density” of the site.
A systems view of sustainability
What makes this example relevant for quality professionals is that it didn’t require breakthrough technology. The innovation came from how the system was viewed.
TRIZ strives for the “ideal final result”—a state where the desired function is performed, but the physical system itself disappears or requires no additional resources. By using the sewer pipes as both a furnace and an air conditioner, NWC moved closer to this ideal. The existing infrastructure became the solution, eliminating the need for a traditional, energy-hungry central plant.
Sustainability emerges naturally when we stop treating constraints as obstacles and start viewing them as untapped resources. Too often, organizations pursue “green” goals by layering new, expensive solutions onto old problems. This case shows that we can find sustainability by taking inventory of available waste and asking how existing systems might serve multiple purposes.
The quality takeaway
The NWC project reminds us that the “quality of waste” depends entirely on our perspective. When we encounter a stubborn bottleneck, the lean response shouldn’t just be, “How do we get rid of this?” but rather, “What latent energy does this bottleneck have?”
By treating infrastructure as a multifunctional asset, NWC didn’t just solve a headache; the team built the largest wastewater heat-recovery system in North America.
That’s operational excellence in its purest, most sustainable form.
Submitted by CG Mistry (not verified) on Mon, 02/23/2026 - 15:31
Feedback
This is an excellent illustration of harnessing energy from unwanted places and use it in a constructive way. TRIZ has to be popularized and advetised for better application.
Submitted by Akhilesh Gulati on Wed, 02/25/2026 - 09:38
In reply to Feedback by CG Mistry (not verified)
Unlocking Hidden Value with TRIZ
Thank you, CG.  I especially like your phrase “harnessing energy from unwanted places.” That is exactly the shift in thinking TRIZ encourages.
What we often label as waste, friction, or infrastructure “problems” is frequently stored value waiting to be recognized. The real constraint is not energy — it’s perspective.
If TRIZ is to be popularized, it will likely be through examples that challenge conventional assumptions about assets and liabilities. If this idea resonates, I’d encourage you to share the article with others who might see infrastructure, and other constraints, differently.  Conversations like this are how new lenses spread.
Submitted by dangermoney on Mon, 03/02/2026 - 11:12
I'm skeptical, given how small ΔT must be for much of the year
"Conventional thinking would frame this as a problem to be mitigated. Instead, the engineering team reframed it as a resource."
Recovering heat from waste streams is a basic premise of heat exchanger network design taught in Chemical Engineering curricula for the last several decades. The exercise is called "heat integration," and it is a very straightforward practice of identifying sinks and sources and matching the necessary energy flows to the streams whose temperature differences are suitable for heat exchange.
Conventional thinking would have explored the possibility of doing exactly what was done here.
Now, whether it would've bitten is another story. I'm curious what the energy balance of the overall system looks like. I strongly suspect that this was a wasteful project that cost much more than the energy than was saved, and most of the benefits probably derive from defining CO2 as a pollutant. I'd be willing to bet that for much of the year, a massive waste stream at room temperature is extremely poor at supplying energy for heating or removing energy for cooling a building, and the annualized HVAC costs probably have hardly changed at all, in contrast to what was probably an enormous capital investment in the heat exchanger network.
Any hard figures we can look at?
About text formats
