When Infrastructure Problems Become Energy Assets
A TRIZ perspective on heat-waste reuse
VividScene303/iStock
Akhilesh Gulati
PIVOT Management Consultants
Mon, 02/23/2026 - 12:03
In the world of quality and lean, waste is the enemy. We hunt for it in cycle times, inventory buffers, and defects. But occasionally we encounter a form of waste so massive and literal that we fail to see it as a resource.
A recent redevelopment project at Denver’s National Western Center (NWC) offers a master class in pivoting from a compliance mindset to a value-creation mindset. The project faced a classic infrastructure bottleneck: two massive, 72 in. wastewater mains running through the heart of the site. Because the effluent within the mains needed to dissipate heat before discharge, building over them was a regulatory and engineering nonstarter.
Conventional thinking would frame this as a problem to be mitigated. Instead, the engineering team reframed it as a resource. By capturing the waste heat from the wastewater flow, the project now uses the sewer system to heat and cool major portions of the campus.
To the traditional eye, these pipes were a constraint. To the TRIZ-trained eye, they were a thermal battery.
Why Remote Work Isn’t Working
ISO 9001:2026 Is Here
Submitted by CG Mistry (not verified) on Mon, 02/23/2026 - 15:31
Feedback
This is an excellent illustration of harnessing energy from unwanted places and use it in a constructive way. TRIZ has to be popularized and advetised for better application.
Submitted by Akhilesh Gulati on Wed, 02/25/2026 - 09:38
In reply to Feedback by CG Mistry (not verified)
Unlocking Hidden Value with TRIZ
Thank you, CG.  I especially like your phrase “harnessing energy from unwanted places.” That is exactly the shift in thinking TRIZ encourages.
What we often label as waste, friction, or infrastructure “problems” is frequently stored value waiting to be recognized. The real constraint is not energy — it’s perspective.
If TRIZ is to be popularized, it will likely be through examples that challenge conventional assumptions about assets and liabilities. If this idea resonates, I’d encourage you to share the article with others who might see infrastructure, and other constraints, differently.  Conversations like this are how new lenses spread.
Submitted by dangermoney on Mon, 03/02/2026 - 11:12
I'm skeptical, given how small ΔT must be for much of the year
"Conventional thinking would frame this as a problem to be mitigated. Instead, the engineering team reframed it as a resource."
Recovering heat from waste streams is a basic premise of heat exchanger network design taught in Chemical Engineering curricula for the last several decades. The exercise is called "heat integration," and it is a very straightforward practice of identifying sinks and sources and matching the necessary energy flows to the streams whose temperature differences are suitable for heat exchange.
Conventional thinking would have explored the possibility of doing exactly what was done here.
Now, whether it would've bitten is another story. I'm curious what the energy balance of the overall system looks like. I strongly suspect that this was a wasteful project that cost much more than the energy than was saved, and most of the benefits probably derive from defining CO2 as a pollutant. I'd be willing to bet that for much of the year, a massive waste stream at room temperature is extremely poor at supplying energy for heating or removing energy for cooling a building, and the annualized HVAC costs probably have hardly changed at all, in contrast to what was probably an enormous capital investment in the heat exchanger network.
Any hard figures we can look at?
