Memory shortages are forcing manufacturers to rethink how they source, qualify, and manage critical electronic components. When approved dynamic random-access memory (DRAM) or NAND flash is unavailable, a seemingly equivalent replacement may appear to be a straightforward purchasing decision. In reality, changing a memory component can affect product performance, reliability, engineering validation, supply-chain traceability, and regulatory compliance.
The pressure is not hypothetical. TrendForce reported on Sept. 30, 2026, that DRAM remains undersupplied and that PC brands are already reducing solid-state drive (SSD) capacities in mainstream models to manage costs. Micron’s annual filing also warns that sustained high prices may lead customers to redesign products to use less memory.
For manufacturers, the implications extend beyond component availability and price. A change in memory manufacturer, device, package, density, or specification can trigger engineering assessments, product requalification, documentation updates, and a review of applicable compliance requirements.
A memory substitution is therefore not simply a purchasing decision. It’s a product change that must be properly assessed before approval. Whether the application is a laptop, industrial controller, or another electronic product, manufacturers need to answer three questions before accepting a replacement: Is it technically equivalent? Is it genuine and traceable? Does the existing compliance documentation still apply?
This article examines these questions and outlines five practical actions manufacturers can take to manage memory shortages while protecting product quality, traceability, and regulatory compliance.
1. The shortage will last, and it will not ease evenly
The market data points in one direction.
Prices: TrendForce projects fourth-quarter 2026 contract prices up 10–15% for conventional DRAM, and 15–20% for NAND flash, quarter on quarter. Increases are slowing, but from a high base, and enterprise SSDs were the only memory category where price growth was expected to accelerate.
PCs: Omdia reported second-quarter 2026 shipments down 3.6% year on year to 65.7 million units, with prices on comparable product lines up roughly 20–40%. It expects the pace of memory and storage cost increases to ease in the second half of 2026, but doesn’t expect prices to reverse this year.
DRAM: TrendForce expects supply to stay tight through 2027, with the supply-demand gap widening. New capacity increases meaningfully only in the second half of 2027, and contributes substantially from 2028.
NAND flash: The same outlook has supply loosening in the second half of 2027 as new production capacity comes online and higher-layer NAND production increases.
Beyond 2027: Micron’s chief executive has said he expects only gradual improvement in 2028.
These are market-level forecasts, not guarantees for any single part. A looser NAND market will not automatically free up the specific qualified SSD in your product. The safe assumption is at least another year in which an approved part can disappear, and in which “same capacity” starts to look like good enough.
2. Is the replacement equivalent?
Mere assurances of equivalence are not good enough because equivalence has to be shown, not assumed. Two memory devices can share a capacity and an interface and still behave differently in your product. Think of the replacement in three layers.
The chip: Voltage, timing, power consumption, and signal integrity can differ, and those differences can affect compatibility with the processor and memory controller. Operating-temperature limits, endurance, and thermal behavior matter most in demanding environments. Even a replacement from the original manufacturer may use a different die revision or process.
The board: Similar package dimensions do not guarantee identical pin assignments, land patterns, or assembly requirements. Changes in package construction, soldering needs, or moisture sensitivity can affect the production line as well as the design.
The firmware: This is where substitutions often quietly go wrong. In DRAM, a change in density, organization, or timing may require adjusted memory-controller settings or fresh system validation. In SSDs and managed NAND, the controller and firmware also handle error correction, wear leveling, and bad-block management, so a different NAND technology, configuration, or controller can change how the drive behaves in the same system.
These are potential risks, not documented failures in any particular product. That’s the point of qualification: to find and control them before a changed part ships. A datasheet comparison is where that work starts, not where it ends. Procurement approval alone is not enough.
3. Is it genuine?
A part can pass every technical check on paper and still not be what it claims to be. When authorized supply runs dry, buyers turn to independent distributors, brokers, and open-market sellers. Not all are risky, but they offer less visibility into a part’s origin, storage history, and handling.
ERAI’s 2025 annual report is the best public evidence, and it needs careful reading.
It’s not a measure of the shortage. Reports fell 29.1% to 748 parts, partly because of a 248-part batch reported by the U.S. government in 2024. The figure is a count of reports, not a marketwide counterfeit rate.
It shows where the risk sits. Programmable logic, analog, microprocessor, and memory ICs were again the largest group of counterfeit-suspect and nonconforming parts. Programmable logic alone was above 15% of reports.
Availability is not protection. Active components, including parts that were readily available, had long lead times, or had unknown lead times, together accounted for 36.15% of reported parts. Avoiding obsolete parts is therefore not a safeguard.
Electrical testing is not enough. ERAI reports that 24% of counterfeit-suspect parts submitted in 2025 passed electrical testing. The organization notes that almost a quarter could evade detection if electrical testing alone were used, and that the actual proportion may be higher, because reporting entities often omit successful test results.
Verification should therefore match the risk. Prefer the original manufacturer or its authorized distributors. Check the full part number, date code, and lot information against supplier traceability. Review certificates of conformity. Add visual inspection, X-ray, or other methods where the source or application warrants it. Keep records that link each purchased lot to its supplier and to the finished products that contain it. Those records matter again in the next step.
4. Does the compliance paperwork still match?
A genuine, qualified part can still arrive with declarations written for a different one. A memory package may contain molding compounds, substrates, lead frames, plating, solder alloys, and, depending on its construction, underfill. A memory module may also include a circuit board, connectors, and labels. Change the manufacturer or package construction and the old material declarations may no longer describe what you ship. A generic supplier statement that a device is “RoHS compliant” is not a substitute for checking the exact manufacturer, part number, and package.
This section covers European Union rules. Products sold elsewhere also face U.K. RoHS, China RoHS, the U.S. Toxic Substances Control Act (TSCA), and U.S. state-level PFAS rules, which differ in scope and obligations. Compliance with one does not establish compliance with another.
RoHS: The Restriction of Hazardous Substances Directive is assessed at the level of homogeneous materials, so a change in package, plating, or solder can change the evidence needed. Lead exemptions are generally irrelevant for typical lead-free, plastic-packaged DRAM and NAND. Where they apply, the detail has just changed: Directive (EU) 2025/1802 split the high-melting-temperature lead exemption into application-specific subentries, applied by member states from July 1, 2026. Subentry 7(a)-IV covers lead-based alloys containing at least 85% lead by weight in specified second-level solder joints used to attach components to printed circuit boards or lead frames. Its applications include solder balls for ceramic ball-grid-array packages and high-temperature plastic overmoldings above 220°C. It’s not a general allowance for BGA packages, and it expires on Dec. 31, 2027, except for applications under Point 24 of Annex III. Confirm the current text in the consolidated directive.
REACH: A new part can change the substance profile of your product. Check its declarations against the current ECHA Candidate List instead of carrying over the old part’s status. Where a listed substance is present above the threshold, assess the resulting communication duties.
PFAS: Separate what’s adopted from what’s proposed. The adopted PFHxA restriction covers specified uses; it’s not a blanket PFAS ban and isn’t aimed at memory devices. The broad classwide proposal is still in review. The Risk Assessment Committee adopted its final opinion on March 2, 2026. The Socio-Economic Analysis Committee agreed on its draft opinion on March 10, 2026, and its final opinion is expected by the end of 2026. After the committees complete their scientific evaluation, their opinions will be submitted to the European Commission, which will consider a restriction proposal for discussion and vote by member states. Track progress on ECHA’s PFAS page.
Until the rules settle, the practical task is better supplier evidence. Ask for:
• The PFAS definition or substance group used
• Whether the statement covers the whole component, including molding compounds, coatings, adhesives, and seals, or only selected materials
• The thresholds and exclusions applied
• The basis: material data, testing, or supplier knowledge
• The issue date, part numbers, and revision, and whether the supplier will notify you when the information changes
A bare “PFAS-free” claim is hard to evaluate without these answers.
5. Five actions manufacturers should take now
Map critical dependencies. List which products use constrained DRAM and NAND, with the approved manufacturer, part number, package, supplier, and inventory for each. Flag single-source parts and long replacement lead times; treat DRAM and NAND separately, since their outlooks differ.
Watch supplier notices. Review product change notifications, end-of-life notices, allocation updates, and published lead times from original manufacturers and authorized distributors. They are often the earliest warning of a forced substitution.
Prequalify alternatives, with their paperwork. Identify second sources while there’s still time. Test them against the chip, board, and firmware checks in Section 2, and collect their compliance declarations at the same moment so an approved alternative is ready technically and documentarily.
Control every change. For each substitution, record the reason, the technical assessment, test evidence, compliance review, and approvals, and update the bill of materials and approved vendor list. Make sure you can trace which part went into which product.
Plan inventory and commitments by scenario. Model different shortage durations and demand levels instead of relying on one forecast. Targeted safety stock may be justified for critical parts. Be cautious about large prepayments and long-term commitments made just to secure scarce supply: Verify the supplier, get allocation and delivery in writing, and check cancellation and nondelivery protections.
Conclusion: Treat every substitution as a product change
The memory shortage is testing more than purchasing power. It’s testing whether a manufacturer can connect sourcing decisions to engineering validation, quality assurance, and regulatory compliance quickly enough to matter. A replacement that fits, functions, and can be delivered is still not safe to ship until it’s equivalent, genuine, and documented.
Resilience isn’t just securing components. It’s securing components that are authentic, qualified, traceable, and compliant.
