Coating Creates Self-Cleaning Toilets That Use a Fraction of the Water
Liquid-entrenched smooth surface (LESS) coating repels bacteria that stink and infect
Wed, 12/18/2019 - 12:00
Every day, more than 141 billion liters of water are used just to flush toilets. The new method dramatically reduces the amount of water needed to flush a conventional toilet, which usually requires six liters.
“Our team has developed a robust bio-inspired, liquid, sludge-, and bacteria-repellent coating that can essentially make a toilet self-cleaning,” says Tak-Sing Wong, professor of engineering and associate professor of mechanical engineering and biomedical engineering at Penn State.
Testing the self-cleaning toilets
Jing Wang, a doctoral graduate from Wong’s lab, co-developed the liquid-entrenched smooth surface (LESS) coating, which is a two-step spray that, among other applications, can be applied to a ceramic toilet bowl. The first spray, created from molecularly grafted polymers, is the initial step in building an extremely smooth and liquid-repellent foundation.
“When it dries, the first spray grows molecules that look like little hairs, with a diameter of about 1,000,000 times thinner than a human’s,” Wang says.
Why Remote Work Isn’t Working
Submitted by William A. Levinson on Wed, 01/01/2020 - 22:56
Good candidate for LEED?
There are LEED (Leadership in Energy and Environmental Design) buildings and even houses that collect greywater (e.g. water that has been used to wash dishes and is no longer drinkable) and then makes it work twice by, for example, flushing a toilet. The additional plumbing necessary to do this, however, increases the capital cost of the building although it is still practical for larger buildings that use a lot of water. This coating, however, can be applied to individual toilets to reduce their water requirements.
Submitted by VV (not verified) on Thu, 10/22/2020 - 00:27
In reply to Good candidate for LEED? by William A. Levinson
Hi.Very interesting
Hi.Very interesting development.
However the water is used not only to clen the tooilet - it is also a transportaton medium to the sewer system.
Regards
