Process Simulation Can Expedite a LSS Implementation
Reality-check your expectations and consensus will follow
Kyle Toppazzini
Thu, 05/23/2013 - 11:36
One of the recurring sentiments I hear from business executives is that lean Six Sigma (LSS) simply takes too long to implement. Without senior management buy-in, implementing it is not only difficult, it’s also nearly impossible. What if there were an easier way that resulted in faster improvements and better engaged the workforce? I believe there is such a way, and it’s through process simulation.
Getting baseline consensus more quickly
Many employees get trapped in overanalyzing the existing process. It’s quite difficult to progress when employees’ experiences and perspectives sway them from accepting the baseline process.
Process simulation tools help to quickly determine what the normal operating process is, as opposed to exception processing. Employees can view how work is completed throughout the process, where work activities become constrained, and where bottlenecks start. Compare the simulation results to the actual process to determine whether the model is capable of reflecting an accurate view. If it can accurately predict performance results, discussions can move away from what the process looks like and steer toward how to improve the existing method.
Why Remote Work Isn’t Working
Submitted by mgraban on Mon, 06/03/2013 - 10:24
"Implement"
Yeah, it takes a long time to change a culture.
If you think the goal is to "implement" Lean (as if it's a piece of software to install), the game is already lost.
I would personally be very surprised if simulation software engaged anyone beyond the engineers or consultants running the simulation software or exercise. Do you have evidence that using simulation "speeds up" Lean, if that's really the long-term goal?
Submitted by Kyle Toppazzini on Mon, 06/03/2013 - 19:34
In reply to "Implement" by mgraban
Mark this article is about
Mark this article is about LSS not lean. If you want examples about LSS I can provide them. Would you like one?
Submitted by mgraban on Mon, 06/03/2013 - 19:51
In reply to Mark this article is about by Kyle Toppazzini
Sure
Yeah, an example?
Submitted by Kyle Toppazzini on Mon, 06/03/2013 - 20:55
In reply to Sure by mgraban
Glad to
The organization's senior management for many years had not been able to agree on a resource allocation model. Several program areas were constantly over budget citing unique reasons for going over budget for their areas.
We implemented LSS coupled with using process simulation techniques that resulted in senior management to agree on a resource allocation model that resulted in all areas coming within budget through improved process performance. This was accomplished within 5 months. Two years later they still come within budget using the techniques and resource allocation process we developed with them.
The employees at all levels had an opportunity to use the process simulation model to 1) validate the existing process, 2) determine which best practices improved overall performance and which did not and 3) optimize the value stream. We used many methods to accomplish this including going to where the work was done to observe the process, mapping the value stream, a detailed data collection and process simulation and use it combination with coaching and mentoring. The key was to use process simulation as a learning and change management too more than an analysis tool. The simulation tool enabled employees to visualize the process from to end to end and observe what worked and what did not.
I encourage you to try it as a learning tool.
Submitted by Rajohnson on Mon, 06/03/2013 - 11:30
Another approach....
During the “Define” phase, use the company’s strategic plan (that has been cascaded to the area of concern) to set a goal for the team to accomplish.  Then coach, mentor, teach, hand-hold, or whatever needs doing to help them accomplish the goal.
By engaging the people doing the work to solve the problem and showing them how the solution improves the overall company has been a fairly well  “tried and true” approach to “implement” a culture change.
Submitted by Kyle Toppazzini on Mon, 06/03/2013 - 18:48
In reply to Another approach.... by Rajohnson
Thank you for your comment
Thank you for your comments
Yes engagement, coaching, mentoring, teaching and effective change management is required throughout all phases. A relentless pursuit to create a learning organization is always a key objective. I have found coupled with this and other strategies, process simulation can add signficant value.
It can be a great asset in demonstrating how employees' contributions increase organizational value.
Submitted by mgraban on Mon, 06/03/2013 - 13:19
Grammar
To the editors:
Shouldn't the headline say "an LSS implementation"?
