The Mystery Measurement Theatre
Determining sources of variations
Steven Ouellette
Thu, 01/14/2010 - 07:40
If you can’t trust your measurement system, you can’t do anything with the data it generates. Last month, in “ Letting You In On a Little Secret,” we talked about the purpose of measurement system analysis (MSA) and I gave you a neat spreadsheet that will do MSA for you, as well as some data (repeated after the jump) from the gauge you want to buy, the Hard-A-Tron. I also left you with a mysterious statement that this study was trickier than it appeared. This month I’ll start off answering a question I received, and then we will see how well the Hard-A-Tron did—and what mysterious thing was going on in the data. After that, if you are good, I’ll give you another set of data to further test a measurement device.
Why Remote Work Isn’t Working
Submitted by RMFix on Fri, 01/15/2010 - 13:43
Steven: Very helpful set of
Steven: Very helpful set of articles re GR&R, thank you. About "...hardness measurement is a Class III destructive test..." Where are such testing classifications described? We are discussing qualification of NDT measurement systems. Are there classifications for nondestructive inspection techniques, for example, eddy current? Are there strategies for calibrating NDT for which there is no NIST traceability? I look forwar to your repy and the next edition of Quality Digest. BR, Robert Fix
Submitted by Steven Ouellette on Wed, 02/03/2010 - 14:51
In reply to Steven: Very helpful set of by RMFix
Hi Robert, and thanks for
Hi Robert, and thanks for reading!
From my Black Belt training...
A destructive gauge is one that possesses an inability to repeatedly assess the true value.
-Class I: The specimen is destroyed, but we are capable of sampling from homogeneous lots or subgroups
-Class II: The specimen is destroyed, and only heterogeneous lots or batches are available
-Class III: Are capable of repeated measuring, but the true value of the specimen is changing
Each can be handled for MSA.
Some apparently NDT are actually destructive. My first MSA was using a micrometer to measure 1-2" thick aluminum plate. Gotta be non-destructive, right? Wrong - the right angle on the carbide faces on the mic were shaving off little curls of aluminum, which when I remeasured the area got smashed, but the measurement was detectably thicker. So a mic on a huge slab of metal was a destructive measure!
I don't know if a classification system for truly ND tests in regards to MSA. In such cases you have a (theoretically) infinite ability to remeasure the same thing, so you should be able to quantify measurement error completely.
"Calibration" is not what we are talking here, and for gauges used for process variables, calibration is frequently irrelevant as long as you have gauge control and acceptability (see my article here: http://www.qualitydigest.com/inside/six-sigma-column/don-t-judge-gauge-… about that - in the section on Long-Term Studies). But, having said that, what you are asking about will be covered in the article on Long-Term Studies, which ought to be the one after next.
Submitted by Fred W on Sat, 01/16/2010 - 06:16
MSA and sampling plans
Great article, Steven. While I strive to promote these concepts and tools at my facility, I question the adequacy of our sampling plans. Take moisture content in coated rolled paper for example. Economics lead us to minimize the number of samples we take to minimize equipment downtime and associated material loss. Measuring moisture content is a destructive testing process as it entails completely drying the sample to measure weight loss. Therefore, conducting an MSA on this process requires an assumption that multiple samples taken from the same area on the roll of paper has the same moisture content, and any variation we see in measurements of these samples is attributed to measurement error. Truthfully, we're skeptical about this assumption, so we feel true measurement system analysis is out of our grasp. How do we compensate for this dilemma with adequate (but economically sound) sample size adjustment?
Submitted by Steven Ouellette on Wed, 02/03/2010 - 14:34
In reply to MSA and sampling plans by Fred W
Thanks for reading,
Thanks for reading, Fred!
What you have is a Class II destructive test. As it is now, you are confounding product and measurement variation. Worst case you can quantify that total variation and use a control chart to alert you when "something" goes wrong, but you won't initially be able to tell if it is process or measurement and you will need to investigate. But there are some tricks we might be able to do, so here are a couple of ideas. Keep in mind it is the measurement system we want to test, and to do so we want to test the exact same thing over and over if we can. But we do have options if we can't. I am going to have to guess at what makes sense for your process, but hopefully either what I am going to say will make sense, or you can make sense of what I say for you process! :-) Ask me if you have questions.
Let's assume you are going to do a potential study.
First, if you can, get a big sample of 10 runs of coated paper (to whatever different nominal moisture losses you make) and put each in a moisture-neutral environment. Not sure how this would look since I don't know what your process or product looks like, but let's say it is a high-humidity box for sake of discussion, maybe each sample has a different humidity setting on each box.
Next, dice up each sample into test sheets. Mix them all together within sample, but keep the different samples separate in their little boxes.
Maintain these in the controlled atmosphere. You now have 10 homogeneous samples from which to draw to perform your MSA - each operator/gauge draws a sample at random from each box (in different random orders!) and measures it. We know we are confounding product with measurement, but by randomizing the test sheets within sample, we hope to have homogenized across that, so anything that stands out on top of that inherent variation (like operator-to-operator or gauge to gauge) is probably gauge related. Basically, we are trying to take it from Class II to closer to a Class I destructive, and we can do the standard MSA on Class I.
Now this is so much trouble that, unless you have doubts about the system you have been using for years (and you might!), it probably makes more sense to do this with 8 bigger samples that you use as during the course of your long-term MSA---which you will get in the article following the next one!
The other option is instead to test the non-destructive components of the system. We start running into concerns about external validity, though, so be cautious. So by that I mean, maybe a mass balance and a dehumidifier are parts of the process. Well, we can test to see that the balance is in control over time by performing an MSA on that, same with the dehumidifier. If both of those exhibit control and acceptability through time, and we see a problem on a measurement, it is a good first assumption that the problem is in the product.
Hmm, maybe I should do an article on destructive gauges?
Submitted by TrainerJim on Fri, 05/18/2012 - 07:43
Destructive Testing
Steven,  I am attempting to measure several properties from a continuous web based coating process where most all measurements are destructive: coating weight, peel force, release force, and shear force.  We also know that our process can inherently produce material whose characteristics are dependent on location vs. independent and random.  I would be very interested in learning about how to perform appropriate measurement system analyses with destructive testing.  Can you offer suggestions on how I can learn about MSA with destructive testing?
