Adobe
ISO 9001:2026, the sixth edition of the quality management systems standard, was published on Sept. 16, 2026, replacing ISO 9001:2015. ISO lists the new edition as Edition 6, 2026-09. ISO/TC 176 confirmed that the Final Draft International Standard (FDIS) was approved ahead of publication.
However, for manufacturers, the Sept. 16 publication shouldn’t be treated as an emergency certification deadline. The more important question is what organizations should do now that the new edition has been published, and how can they use the transition period to strengthen their quality management systems rather than simply update documents for the next audit.
A transition period up to three years is anticipated in certification-sector guidance, potentially taking organizations into 2029. However, organizations should rely on the applicable arrangements established through the accreditation and certification system rather than treating September 2029 as a formally confirmed universal deadline. ISO advises certified organizations to work with their certification bodies on the applicable transition time frame.
A revision, not a wholesale redesign
ISO 9001:2026 doesn’t abandon the fundamental architecture that organizations have built around ISO 9001:2015. Process approach, customer focus, leadership, risk-based thinking, and continual improvement remain central to the quality management system.
The revision instead introduces targeted changes and clarifications intended to make the standard more relevant to today’s business environment. ANSI describes the 2026 edition as maintaining the core framework while introducing changes around quality culture, ethical behavior, risks and opportunities, change management, terminology, and related areas.
For manufacturers with mature ISO 9001:2015 systems, this distinction matters. The transition should begin with a structured gap assessment, not a wholesale rewrite of the QMS.
How the revision reached this point
The 2026 edition is the result of a multiyear international revision process rather than a rapid rewrite.
In February 2026, ISO/TC 176 reported that 83 experts representing 42 national standards bodies and 12 liaison organizations participated in a working-group meeting in Mexico City. The group reached consensus on the technical requirements for clauses 1–10 before moving on to finalizing informative material, including Annex A and the introduction.
That development history is relevant for manufacturers because it reinforces the international, consensus-based nature of the revision.
Seven areas manufacturers should watch
1. Climate change and organizational context
Climate change isn’t entirely new to ISO 9001. In 2024, ISO and the International Accreditation Forum introduced amendments requiring organizations to determine whether climate change is a relevant issue and recognizing that interested parties can have climate-related requirements.
ISO 9001:2026 carries this consideration into the revised framework, particularly through Clauses 4.1 and 4.2, which address the organization’s context and the needs and expectations of interested parties.
For manufacturers, the practical question isn’t whether the quality function suddenly becomes responsible for climate strategy. Instead, organizations should determine whether climate-related issues can affect their QMS. Extreme weather can affect suppliers, transportation, facilities, and production continuity, while customer requirements might introduce climate-related expectations into supply chains.
The key is relevance. Where climate change affects the organization’s ability to achieve intended QMS results, it should be considered within existing management processes rather than treated as a separate compliance exercise.
2. Quality culture and ethical behavior move to the fore
One of the most significant changes is the stronger treatment of quality culture and ethical behavior. BSI identifies Clauses 5.1.1 and 7.3 as placing greater emphasis on quality culture, ethical behavior, and leadership accountability.
This matters because quality culture can’t be created simply by adding another procedure. Consider a manufacturing environment where employees are under pressure to meet production targets and are reluctant to report defects because stopping a production line could affect delivery performance. The organization may have an extensive QMS, but its actual quality culture could still be weak.
The transition provides an opportunity for management to examine how quality decisions are made in practice. Organizations should consider whether employees can escalate problems, whether management responds consistently to quality concerns, and whether ethical expectations are understood beyond the quality department.
Certification-body guidance also highlights the importance of practical evidence when organizations demonstrate quality culture and ethical behavior. SGS Thailand guidance notes that auditors may examine leadership decisions, shop-floor authority, management-review minutes, and awareness records rather than relying only on documented policies.
3. Risks and opportunities receive clearer treatment
Risk-based thinking remains an important part of ISO 9001, but the 2026 revision provides a clearer distinction between risks and opportunities in Clause 6.1, with separate consideration of actions to address each.
For manufacturers, this is an opportunity to move beyond a traditional risk register. Supplier failures, equipment breakdowns, regulatory changes, and process variation may represent risks, while automation, process improvements, better supplier performance, and new inspection technologies may create opportunities.
The distinction is important. An effective QMS should not only help prevent undesirable outcomes but also help organizations identify opportunities to improve processes and business performance.
4. Change management becomes increasingly important
Manufacturing rarely stands still. Materials are substituted, suppliers change, production moves between facilities, software is updated, equipment is replaced, and products are redesigned. Each change can introduce quality risks, particularly when its consequences extend beyond the function initiating the change.
Clause 6.3 reinforces planning for QMS changes, including consideration of resources, responsibilities, communication, monitoring of effectiveness, and review of outcomes.
Manufacturers should examine whether their change-control processes consistently consider quality effects before changes are implemented. A component substitution, for example, might begin as a procurement decision but could affect product performance, reliability, regulatory compliance, and customer requirements.
5. Workforce awareness must go beyond the quality policy
The revised approach also places greater emphasis on awareness. Clause 7.3 connects employee awareness more explicitly with organizational quality culture and ethical behavior.
Manufacturers should consider whether employees understand:
• How their work affects QMS performance
• What quality requirements apply to their activities
• What happens when requirements aren’t met
• What quality and ethical behaviors the organization expects
• How they should respond when production pressures conflict with quality requirements
Training should be connected to actual responsibilities and decisions rather than treated as a box-ticking exercise.
6. Quality needs stronger alignment with business strategy
A quality department shouldn’t operate as a parallel compliance function that becomes visible only during an audit. Quality information can support decisions involving suppliers, production capacity, customer requirements, product changes, process investment, and business risks.
The revised standard’s emphasis on organizational context, leadership, and quality culture provides an opportunity to examine whether quality objectives genuinely support broader business objectives.
If the QMS produces large volumes of data but little useful information for management decisions, the problem might not be the amount of data. It could be how that information is connected to business planning and operational decision-making.
7. Terminology and structure are being clarified
Clause 3 of ISO 9001:2026 includes QMS-specific terms and definitions, while ISO 9000 remains the broader normative reference for quality-management terminology.
This change sits alongside the publication of ISO 9000:2026, the fifth edition of the quality-management fundamentals and vocabulary standard, which was published in May 2026.
For multinational manufacturers, clearer terminology can be particularly valuable when quality systems span multiple countries, sites, and functions. Consistent interpretation of quality-management concepts can reduce ambiguity between corporate teams, manufacturing sites, suppliers, and certification bodies.
What hasn’t changed?
This is an important part of the story, because ISO 9001:2026 shouldn’t be presented as a completely new quality management philosophy.
The core framework remains intact. Organizations will continue to work with the process approach, customer focus, leadership, risk-based thinking, performance evaluation, and continual improvement. ISO describes the 2026 edition as building on the proven foundation of ISO 9001:2015 rather than replacing it with a completely new approach.
That means companies with effective ISO 9001:2015 systems shouldn’t assume that a complete rebuild is necessary. Instead, they should identify where the existing system already meets the revised requirements, and focus resources on genuine gaps.
The practical challenge is to distinguish new requirements from clarified expectations. An organization shouldn’t create a new form, register, or procedure merely because a revised clause uses different language.
ISO 9001 is changing alongside other management standards
ISO 9001 isn’t changing in isolation. ISO 14001:2026, the environmental management systems standard, was published on April 15, 2026. ISO says the new edition provides a clearer framework and stronger alignment with current environmental priorities.
At the same time, ISO 45001 is also being revised. The revised occupational health and safety standard has progressed through the Draft International Standard stage in 2026, and ISO has previously indicated that the revised edition is expected to be published in 2027.
For manufacturers operating integrated management systems, these developments create an opportunity to look beyond individual standards. Quality, environmental, and occupational health and safety systems often depend on the same processes, leadership structures, operational controls, and supplier relationships.
A coordinated approach could reduce duplication and make management-system information more useful to the business.
What manufacturers should do during the first 90 days
The first 90 days after publication should be treated as a planning and assessment period, not a race to rewrite procedures.
First 30 days: Understand the changes
• Obtain and review the final ISO 9001:2026 standard.
• Compare the revised requirements with the existing QMS.
• Brief senior leadership and key process owners.
• Identify potentially affected processes.
• Contact the certification body for its transition requirements and audit planning.
Days 31 to 60: Conduct a focused gap assessment
The assessment should examine:
• Clauses 4.1 and 4.2, including climate-related considerations where relevant
• Clause 5.1.1, leadership, quality culture, and ethical behavior
• Clause 6.1, risks and opportunities
• Clause 6.3, planning of changes
• Clause 7.3, workforce awareness
• Clause 3, terminology
• Internal audit and management-review processes
• Supplier and externally provided processes
The objective should be to identify real gaps, not automatically create new documentation.
Days 61 to 90: Build the implementation road map
Once the gaps are understood, organizations should assign owners, establish priorities, and integrate improvements into their existing QMS activities.
Some changes may require revised procedures or records. Others may require management engagement, employee training, or improvements in how quality information is used.
Most important, organizations should align the transition with their certification cycle rather than creating a disconnected ISO project.
Use the transition period wisely
Certification-body guidance, including NQA’s current transition guidance, anticipates a transition period of up to three years, potentially extending into 2029. Organizations should rely on the applicable arrangements established through the accreditation and certification system rather than treating September 2029 as a formally confirmed universal deadline. ISO advises certified organizations to work with their certification bodies on the applicable transition time frame.
Waiting until the final year, however, could turn a manageable transition into a rushed compliance exercise.
Organizations that begin early can incorporate the changes into normal internal-audit, management-review, and continual-improvement cycles. This approach is likely to be more effective than launching a separate documentation project immediately before certification.
The better question is not, “How quickly can we update the QMS?” but, “How can we use the transition to make the QMS more effective?”
The real opportunity lies beyond certification
ISO 9001:2026 arrives at a time when manufacturers are dealing with increasingly complex supply chains, regulatory requirements, technology changes, and customer expectations.
The revision doesn’t require organizations to abandon what already works. Instead, it provides an opportunity to examine whether the QMS reflects how the business actually operates and makes decisions.
Manufacturers should ask whether quality information reaches decision-makers, whether employees can escalate problems, whether leadership demonstrates the expected quality culture, whether risks and opportunities are actively managed, and whether changes are evaluated for their wider consequences.
Those questions go beyond certification.
The publication milestone was Sept. 16, but the more important milestone is what manufacturers do during the transition period that follows.
Organizations that use the revision to strengthen decision-making, change management, supplier oversight, workforce awareness, and quality governance will gain considerably more from ISO 9001:2026 than those that treat it simply as another documentation exercise.
