Precision Mid- to High-Temperature Blackbody Calibration Source
Unique spherical cavity design produces superior results
Process Sensors Corp.
Thu, 01/13/2011 - 15:31
(Process Sensors Corp.: Franklin Lakes, NJ) -- Process Sensor Corp., a manufacturer and distributor of noncontact infrared temperature and moisture measurement instruments, announces its high-accuracy bench-type blackbody calibration source, design model BBS 1150, that features high emissivity of +0.995, a large 2 in. diameter aperture, and a superior uniformly heated spherical cavity.
The BBS 1150 blackbody calibration source offers a wide temperature range from 200°C to 1,150°C and is controlled by a precision proportional-integral-derivative (PID) controller that provides user-selectable push buttons, allowing for quick and simple adjustment of the desired set point temperature.
The BBS 1150 will attain the set point temperature and stabilize to produce a temperature reading to within 0.5°C, ensuring high-accuracy calibration of instruments including noncontact infrared thermometers, thermal imaging camera systems, single element and focal plane array detectors, spectrophotometers, heat flux meters, laser systems, and more.
Detailed specification information is posted at www.processsensorsir.com/blackbody.
Why Remote Work Isn’t Working
Run It Past the Murder Board
