Seen at IMTS
Synova Laser MicroJet Integration Package Debuts in Chicago
Adapted to a standard three-axis vertical machining center
Mon, 10/28/2024 - 12:00
(Synova: Totowa, NJ) -- At the International Manufacturing and Technology Show in Chicago in September 2024, Synova, a provider of advanced laser cutting solutions, presented its Laser MicroJet Integration Package (LMJ-iP), designed to turn any standard three-axis vertical machining center into a multipurpose milling/drilling, laser-cutting machine.
The LMJ-iP is Synova’s core laser technology, consisting of standard hardware components designed for easy integration into new or existing three-axis VMC machines. The standard integration package includes everything you need to get started: cutting head, laser, fiber cable, high-pressure pump, and power meter.
Run It Past the Murder Board
