The Problem Isn’t the Problem
How TRIZ helps quality professionals rethink trade-offs and contradictions
Spencer James Lucas / Unsplash
Akhilesh Gulati
PIVOT Management Consultants
Mon, 06/08/2026 - 12:03
The hardest problems are often not the ones we fail to understand. They’re the ones that resist every reasonable attempt to solve them.
We improve quality, but slow production. We add control, but lose flexibility. We simplify one part of a process, only to create instability somewhere else.
Eventually, someone says, “That’s just the nature of the system.”
But what if it isn’t? What if many of the trade-offs we accept are actually signs that we are framing the problem incorrectly?
Those questions are at the heart of TRIZ.
Where TRIZ came from
TRIZ is the Russian acronym for Teoriya Resheniya Izobretatelskikh Zadach, translated as “Theory of Inventive Problem Solving.”
Beginning in 1946, Soviet researcher Genrich Altshuller and his colleagues studied hundreds of thousands—and eventually millions—of patents to understand how innovation occurs.
What they discovered was surprising:
• Problems and solutions repeat in many industries.
• Patterns of technical evolution repeat in many industries.
• Breakthroughs often come from applying principles from one field to another.
In other words, innovation isn’t entirely random. Many inventive solutions follow recognizable patterns. TRIZ was developed as a way to identify and apply those patterns systematically.
The contradiction underneath the problem
One of the central ideas in TRIZ is that difficult problems are often contradictions. Improving one thing causes something else to worsen.
As quality professionals, we encounter this constantly. If we increase inspection, throughput suffers. If we reduce variation, flexibility decreases. If we improve safety, complexity increases.
Most organizations learn to manage these trade-offs. But TRIZ starts with a different assumption: What if the trade-off itself can be resolved? Instead of optimizing the compromise, TRIZ asks, “How do we eliminate the need for compromise?”
How TRIZ translates problems
One of the unusual aspects of TRIZ is that it converts specific engineering problems into generalized contradiction patterns. Instead of describing a problem only in industry-specific language, TRIZ asks two broader questions:
• What are we trying to improve?
• What gets worse as a result?
To make this systematic, TRIZ defines 39 common engineering parameters—things like reliability, speed, complexity, accuracy, and harmful side effects. These are organized inside one of the best-known TRIZ tools: the Contradiction Matrix.
The matrix connects conflicting parameters with 40 recurring inventive principles—solution patterns that repeatedly appeared in successful innovations across many industries.
The matrix doesn’t provide a ready-made answer. It provides direction. It helps teams look beyond the assumptions of their own field and explore solution paths that have already worked elsewhere under similar contradiction structures.
The Contradiction Matrix is only one part of the broader TRIZ methodology. TRIZ also includes concepts such as:
• The ideal final result (IFR), which encourages teams to envision the desired outcome with minimal complexity or cost
• Functional analysis, which examines how system elements interact
• Patterns of evolution, which identify recurring ways technologies tend to develop over time.
Together, these approaches help teams move beyond incremental improvement toward more inventive forms of problem solving.
For many first-time users, this translation step feels unfamiliar because engineers naturally describe problems in the language of their own industry. TRIZ deliberately abstracts the problem into a more general form.
Paradoxically, that abstraction is what makes the method powerful. Once the problem becomes structurally recognizable, it also becomes comparable to thousands of previously solved problems from entirely different domains.
A story about bubbles
A disk manufacturer once faced a persistent coating problem: Microscopic bubbles forming in the applied layer created defects and reliability issues.
The engineering team tried the expected fixes:
• Filtering the liquid
• Adjusting temperatures
• Modifying spin speeds
• Tightening process controls
• Degassing the material
The problem improved temporarily but never disappeared consistently.
Eventually, the problem was reframed. Instead of asking, “How do we eliminate bubbles?” the question became, “Where else are bubbles treated as something important enough to control precisely?”
That led to an unexpected product: champagne. In champagne production, bubbles aren’t defects. They’re a carefully managed phenomenon. Producers understand where bubbles form, how they grow, and the conditions that influence them.
The industries had little in common operationally, but they shared a similar underlying mechanism involving gas formation in fluids. In TRIZ terms, the engineering team had reframed the issue as a contradiction between improving reliability while increasing harmful side effects.
The Contradiction Matrix pointed toward several recurring solution approaches, including one called Preliminary Action—addressing part of the problem before the critical process step occurs.
That principle redirected the thinking completely. Instead of trying to stop bubbles during coating, the engineers focused on controlling where and when bubbles could form before the coating stage began. The eventual solution involved:
• Reducing random nucleation sites
• Controlling dissolved gases
• Minimizing turbulence and pressure variation
• Forcing bubble formation earlier in the process where it could be managed safely
The manufacturer didn’t copy champagne production methods directly. What transferred was the underlying logic of bubble behavior—the physical mechanism in two very different industrial processes.
That distinction matters. TRIZ isn’t about borrowing products or technologies from other industries. It’s about recognizing recurring patterns beneath apparently different problems.
A story closer to home
A dairy farm faced a different, less-glamorous challenge. Manure needed to be dried before it could be transported for fertilizer use. Traditional sun drying created significant odor problems. Industrial heating systems were considered but proved too expensive.
Again, the breakthrough came from reframing the problem. The question became, “How do we remove moisture without creating unacceptable environmental effects?” That change led the team to examine dehydration and concentration approaches used in other industries, including food-processing systems. Their equipment was different, but it solved the same problem.
New solution pathways emerged.
Why this matters for quality professionals
TRIZ isn’t a replacement for lean, Six Sigma, robust design, QFD, Taguchi Methods, or other quality disciplines. In many organizations, it works best alongside them:
• Lean can expose waste.
• Six Sigma can reduce variation.
• Statistical tools can identify instability.
But when teams become trapped inside what appears to be an unavoidable trade-off, TRIZ offers a structured way to challenge the assumption that the trade-off must exist at all.
That may be its most valuable contribution.
A different starting point
If this is your first exposure to TRIZ, start with something simple. The next time a problem feels stuck, ask, “What am I trying to improve?” and, “What gets worse when I do?”
Then ask one more question: “Where else might this same contradiction already have been solved?”
The disk manufacturer didn’t expect to learn from champagne producers. The dairy farm didn’t expect to learn from food-processing systems. They were simply following the structure of the contradiction instead of the surface appearance of the problem.
And sometimes, that’s what TRIZ really provides—a disciplined way of asking questions that lead to solutions we wouldn’t otherwise think to pursue.
Footnote
For readers interested in deeper study, several organizations now offer introductory as well as advanced TRIZ training and certification programs covering contradiction analysis, inventive principles, system evolution, and related tools. Two of the most prominent are:
MATRIZ—Established by followers and colleagues of Genrich Altshuller, the creator of TRIZ, the international TRIZ association is headquartered in Warsaw, Poland.
Altshuller Institute for TRIZ Studies—A nonprofit organization based in Worcester, Massachusetts, the Altshuller Institute has helped popularize TRIZ among quality and innovation professionals in the United States and beyond.
Submitted by C.G (not verified) on Mon, 06/08/2026 - 12:46
TRIZ Application
Akhilesh has done an awesome job at highlighting the use of TRIZ in unconventional areas.
This problem solving method needs to be used at many problem solving presentations and industries.
Submitted by Vn (not verified) on Tue, 06/09/2026 - 01:40
TRIZ
Very good examples given to explain simplicity and corelations
About text formats
