The Problem Isn’t the Problem
How TRIZ helps quality professionals rethink trade-offs and contradictions
Spencer James Lucas / Unsplash
Akhilesh Gulati
PIVOT Management Consultants
Mon, 06/08/2026 - 12:03
The hardest problems are often not the ones we fail to understand. They’re the ones that resist every reasonable attempt to solve them.
We improve quality, but slow production. We add control, but lose flexibility. We simplify one part of a process, only to create instability somewhere else.
Eventually, someone says, “That’s just the nature of the system.”
But what if it isn’t? What if many of the trade-offs we accept are actually signs that we are framing the problem incorrectly?
Those questions are at the heart of TRIZ.
Where TRIZ came from
TRIZ is the Russian acronym for Teoriya Resheniya Izobretatelskikh Zadach, translated as “Theory of Inventive Problem Solving.”
Beginning in 1946, Soviet researcher Genrich Altshuller and his colleagues studied hundreds of thousands—and eventually millions—of patents to understand how innovation occurs.
What they discovered was surprising:
• Problems and solutions repeat in many industries.
• Patterns of technical evolution repeat in many industries.
• Breakthroughs often come from applying principles from one field to another.
Submitted by C.G (not verified) on Mon, 06/08/2026 - 12:46
TRIZ Application
Akhilesh has done an awesome job at highlighting the use of TRIZ in unconventional areas.
This problem solving method needs to be used at many problem solving presentations and industries.
Submitted by Akhilesh Gulati on Tue, 08/25/2026 - 16:35
In reply to TRIZ Application by C.G (not verified)
Sharing the methodology at Universities
Thank you CG.  Please share the methodology with your students at the various classes you teach.  It will help use resources better and with better outcomes, rather than trade-offs.
Submitted by Vn (not verified) on Tue, 06/09/2026 - 01:40
TRIZ
Very good examples given to explain simplicity and corelations
Submitted by Akhilesh Gulati on Tue, 08/25/2026 - 16:31
In reply to TRIZ by Vn (not verified)
TRIZ - please share your experience
Thank you VN. I don't know whether you were already familiar with TRIZ.  If you were, could you please share how you have used it / seen it used.  And if this was a new approach for you, please share how you have been able to apply it.
Thanks again.
