ISO 9001:2026 requires organizations to determine the relevance of climate change to their QMS
Dave Meckler / Unsplash
Brad Pleima
EcoEngineers
Wed, 11/18/2026 - 12:03
What does climate change have to do with quality? It’s a question that QA professionals have been expected to answer since climate considerations were introduced into ISO 9001 in 2024. Following a September 2026 update, we now need to be able to provide evidence for the answer.
This shouldn’t be hard. During the last year, the effects of climate change have been increasingly showing up in the things that quality managers are accountable for. The opportunity now is to demonstrate not only how quality management can help businesses and organizations manage these risks, but also how it can improve products and operations in the process.
This summer made the case
Europe’s heat wave and drought pushed the Rhine River to very low levels in August 2026, disrupting a critical transport route for European industry. The river carries raw materials and active ingredients from North Sea ports to manufacturing sites in Germany and Switzerland. When shipping is restricted, manufacturers face the prospect of delayed deliveries, changes to transport conditions, or having to source materials from suppliers they haven’t previously qualified.
Food manufacturers have faced similar challenges, scrambling to find new sources and reformulate when extreme weather hits the ingredients that nobody was watching. Even a second supplier is little comfort if the same heat wave hits both regions.
But the risks go beyond supply chains. Extreme heat can also make working conditions unsafe, affecting employee well-being and productivity. From sourcing ingredients to keeping production lines running, climate change presents a very real threat to business operations at multiple levels.
Whether it’s held up by conflict in the Middle East or a river too low for barges, a late shipment is still a late shipment. Either way, someone in quality ends up handling the deviation, the paperwork, and the call to the customer. The same goes for out-of-spec materials, temperature excursions, and rushed process changes. The difference is the cause.
Why ‘not relevant’ won’t cut it
Climate change entered ISO 9001 through a 2024 amendment. The newly published ISO 9001:2026 builds it into the standard itself. Organizations must determine whether climate change is relevant to their quality management system, including its ability to achieve intended results.
Some organizations will conclude that it doesn’t, and for some businesses that’s a legitimate answer. But I’d urge anyone tempted to write “not relevant” and move on to think again, because an assertion is not evidence. If an auditor asks how you reached that conclusion, “we didn’t think it applied” isn’t a position you want to defend under the new guidelines—particularly after a summer like the one we’ve seen this year, with a powerful El Niño predicted for 2027. This ISO 9001 update is an opportunity to truly assess how climate affects your business. Checking a “not relevant” box without the diligence to better understand your climate risks leaves your business open to legitimate risk.
You already have the tools
The good news is that quality teams don’t need to start from scratch. They’re already experienced in risk assessment, supplier management, change control, and continuous improvement. The challenge is applying those established processes to climate-related issues.
I’d recommend starting with four practical steps.
1. Assess where your organization might be exposed
Look at the processes that are most important to delivering consistent products and services. Which materials depend on geographically concentrated suppliers? Which processes rely on tightly controlled temperatures? Could extreme weather interrupt power supplies, logistics, or production?
A pharmaceutical manufacturer, for example, might start by reviewing temperature excursion records, storage requirements, and the reliability of its cold-chain logistics providers.
The purpose isn’t to catalog every possible climate event. It’s to identify where changing conditions could have a material effect on product quality, compliance, or customer commitments.
2. Establish what you’re already doing
Many businesses will discover they’re already managing climate-related risks without necessarily recognizing them as such.
A manufacturer may have introduced additional temperature monitoring, diversified its supplier base, or improved energy efficiency. These measures may already help protect product quality against changing conditions.
Review existing risk registers, supplier assessments, deviation records, and operational data before introducing new processes. This helps identify both the controls already in place and any gaps that need attention.
3. Evaluate the options against business and quality objectives
Identifying a risk is only useful if it informs a decision.
Take a food manufacturer whose primary ingredient supplier is increasingly exposed to drought. Qualifying an alternative supplier might reduce the risk of disruption, but the business still needs to assess whether the replacement ingredient meets its specifications, whether production processes need adjusting, and what additional costs might be involved.
Similarly, improving cooling equipment could help reduce the likelihood of temperature excursions while also lowering energy consumption and operating costs.
The strongest decisions are those that make sense for product quality, operational performance, and the wider business.
4. Measure the results and keep the evidence
Once changes have been introduced, quality managers should establish whether they’re delivering the intended improvements.
Depending on the process, that could mean monitoring supplier delivery performance, recording temperature excursions, assessing rejected batches, or comparing energy consumption before and after equipment upgrades.
Existing quality metrics provide a useful starting point. Where an organization also wants to quantify environmental benefits, established emissions data, calculation tools, or life-cycle assessments may offer further evidence.
The important point is to measure before making claims. Whether an organization is demonstrating improved process reliability, reduced operating costs, or lower emissions, its conclusions should be supported by data.
Look beyond compliance
There’s a tendency to view new ISO requirements as another administrative burden. But assessing climate-related risks can also reveal opportunities to improve how a business operates. Reducing energy consumption, for example, may lower costs as well as environmental effects. Improving supplier visibility can reduce disruption and strengthen customer confidence. Better monitoring of production conditions can help identify inefficiencies before they result in nonconforming products.
Not every improvement requires substantial investment, either. Organizations can begin by reviewing the information they already hold and identifying relatively small changes that could deliver measurable benefits. A useful starting point is to select one climate-related risk, establish its current effects, introduce a proportionate control, and monitor whether that control works. That follows the same principles of continuous improvement that quality professionals already apply every day.
What isn’t being asked of you
It’s important to be clear about the limits. ISO 9001 doesn’t automatically require organizations to introduce emissions-reduction targets or carbon accounting programs simply because climate change has been identified as a relevant issue. Quality teams don’t need to become sustainability teams. What they do need is to demonstrate that they’ve considered whether climate change is relevant to their quality management system and, where it is, how the associated risks and opportunities are being addressed. That evidence doesn’t necessarily need to be complicated. An assessment of relevant suppliers and operations, supported by risk records, management review discussions, and the rationale behind decisions, may provide a useful foundation. The important thing is that evidence reflects how the organization actually operates, rather than existing solely to satisfy an auditor.
I’d bet that most organizations are already doing something to mitigate climate risk, and this new ISO 9001 update is an opportunity to reexamine, assess, and document work previously done.
Ethical conduct: What does an auditor actually look for?
The revised standard also places greater emphasis on quality culture and ethical conduct. Although these might seem separate from climate considerations, both come down to how organizations make decisions when their systems are under pressure.
Take a warehouse that hits its temperature limit during a heat wave. A sensor logs an excursion on Friday night, and the shipment is due out Monday. Does the person who spots it quarantine the stock and tell the customer, or adjust the log and hope the product held up? Nobody audits that moment, but an auditor can see its fingerprints in the records, in the deviation log, and in what the night shift says when asked.
Auditors can’t observe every decision, but they can examine the evidence it leaves behind: deviation records, corrective actions, management decisions, and conversations with employees. The same principle applies when a climate-related disruption creates pressure to change suppliers or production processes on short notice. Does the organization follow its established change control procedures, or does it allow commercial pressures to override them? Quality culture is demonstrated through these decisions, particularly when maintaining standards is inconvenient.
The bottom line
Climate change doesn’t require quality professionals to reinvent their management systems. It requires them to apply established quality principles to risks and opportunities that might previously have gone unrecognized.
Start by reviewing the operations and suppliers most exposed to disruption. Examine the controls already in place, identify gaps, and consider improvements that support both product quality and business performance.
Above all, document the reasoning and measure the results.
Organizations that take this approach will have a clearer understanding of the vulnerabilities in their operations and where practical improvements can make a difference.
Submitted by Dr. Marco V. Jacquez (not verified) on Wed, 11/18/2026 - 11:27
The climate changes naturally
I have been working in Quality 27+ years, and the inclusion of the climate change into the QMS does not make any sense to me. The climate changes naturally, there are patterns that last a year, ten years, one hundred years. A bad weather in one year does not explain the "climate change" it occurs naturally.
About text formats
