Most early-stage medical device companies never decide to skip a quality management system (QMS). They just never decide to buy one. The founding team opens a shared drive, builds a spreadsheet for design inputs and outputs, starts a document register in another tab, and agrees to sort out the real system closer to submission. On the invoice, that approach costs nothing. But that zero is exactly why it ends up being so expensive.
Building your own QMS in spreadsheets and folders is one of the most common ways medical device companies experience the “cost of doing nothing.” The tools feel free because the price never lands in one place. Instead, it’s spread across rework, lost traceability, and audit risk. By the time you add it up, it dwarfs the subscription you were avoiding.
Where the cost actually hides
A QMS isn’t one document but rather the connected set of processes a medtech company runs to prove its device is safe and effective: document control, training records, design controls and the design and development file (DDF), risk management, corrective and preventive action (CAPA), complaint handling, supplier management, audit management, and change control. On a build-your-own setup, each of these starts life as a tab or a folder. Each one looks manageable in isolation. Likewise, the expense isn’t in any single sheet. It’s in keeping all of them current, consistent, and connected to each other, by hand, forever.
The trouble with running one process this way is already well documented. Managing design controls on spreadsheets always results in broken revision control and missing links to risk management. But that’s just a single function. A whole QMS build takes the same failure and repeats it across nine process areas at once, then adds a tenth problem no individual spreadsheet has on its own: the connections (or lack thereof) between them.
The manual tasks are where it gets expensive
In a purpose-built system, a change to a design input ripples automatically to the outputs it drives, the verification tests that cover it, the risks it affects, and any CAPA tied to those risks. In a spreadsheet build, none of those references are live. Update one cell, and the related records in five other files fall out of date. The system doesn’t fail spectacularly. It drifts, and the gap stays invisible until an auditor pulls one thread and things unravel.
Adding up the bill
The hidden cost of doing nothing tends to build in four places.
The first is maintenance labor. Every sheet needs an owner, and that owner spends hours on version control that dedicated QMS software would handle on its own: renaming files, reconciling two people’s edits, resending the current copy, rebuilding a tracker after someone sorted a column the wrong way. None of that work moves the device closer to market; it exists purely to keep a fragile workaround from collapsing.
The second is broken traceability, which is where compliance risk concentrates. The U.S. Food and Drug Administration’s design control requirements under 21 CFR 820 expect a traceable DDF, and the Quality Management System Regulation (QMSR), in effect since Feb. 2, 2026, folds ISO 13485:2016 and its documented-information requirements into U.S. law. Traceability that depends on a person remembering to update six files is not traceability you can count on. Gaps turn into findings, and findings turn into delays.
The third is audit and submission prep. When evidence is scattered across folders and tabs, getting ready for an audit or assembling a 510(k) means rebuilding the record from scratch, hunting for the current revision, screenshooting spreadsheets, and chasing signatures that were never captured in a controlled way.
The fourth is data integrity, and it’s the one auditors probe hardest. A general-purpose spreadsheet doesn’t provide the time-stamped, computer-generated audit trail or the controlled electronic signatures that 21 CFR Part 11 requires for electronic records. An editable Excel file with no record of who changed what, and when, hands a reviewer a reason to question the numbers in it. Layer key-person risk on top, where the logic of the entire system lives in one employee’s head, and a single resignation can turn a passable setup into a map nobody else can read.
Underneath all four sits the biggest cost of the build-your-own approach. The hours your founders and engineers pour into maintaining a quality system are hours they’re not spending on the product. For a premarket team racing a submission window, that trade can be the whole ballgame.
The bill also grows with the company. A spreadsheet system that can hold together at five people quickly becomes unworkable at 30, when there are more devices in flight, more design changes, more suppliers to qualify, and more hands editing the same files with no controlled way to see who touched what. The workaround doesn’t break on a schedule you get to choose. It breaks when a new hire can’t find the current procedure, or when a notified body asks for a change history that the folders simply can’t produce.
Deferral is the most expensive option
The standard answer to all of this is to fix it later, closer to submission, when there is budget and time to spare. But cleanup always costs more than setup. A record that was never captured correctly can’t be rebuilt cleanly a year after the fact, and remediating 12 months of untraceable design decisions under submission pressure is far harder than doing it right the first time. Six months of delay is rarely bad luck. More often it’s the bill for a build-your-own QMS finally coming due.
A right-sized QMS eliminates the hidden costs of paper
None of this argues for a sprawling, enterprise-grade quality system that takes a year to stand up. Early teams are right to resist that. The real alternative to the spreadsheet build is a right-sized system: enough structure to hold the foundational processes without the extras a startup has no use for yet. A premarket team needs document control, design controls, risk management, and a handful of core records working together from Day One, not a hundred modules it will never touch.
Greenlight Guru’s eQMS is built for exactly that. It gives early medtech teams design controls, risk management, document control, CAPA, and supplier and audit management in one place, with traceability built into the records as the work happens instead of reconstructed the night before an audit. It maps to ISO 13485 and the QMSR out of the box, and because it connects to the tools engineers already use, like Jira and GitHub, the work they do gets captured.
To see how Greenlight Guru’s premarket eQMS gives early medtech teams a quality system that is audit-ready from the start, check out this free demo.
Published Aug. 24, 2026, by Greenlight Guru.
The point that a “free”…
The point that a “free” spreadsheet QMS fails at the *connections* between CAPA, supplier records, complaints, and audits matches what we see when supplier 8Ds land on a customer’s desk.
The reports that get bounced rarely miss a discipline label. They fail because D2 never bounds the suspect population, D4 stops at occurrence and never names the escape control that should have caught it, and D7 claims “FMEA / control plan updated” with no revision ID. When evidence lives in five folders, those gaps stay invisible until the customer’s auditor pulls one thread.
A useful pre-send habit: for every claim, name the document, measurement, or date that proves it. If nothing can be pointed to, that discipline is not ready to send.
Free 8D/D4 checklist (advisory, no invented evidence): https://8d-gate.vercel.app/?utm_source=qualitydigest&utm_medium=comment&utm_campaign=hidden-cost-qms#email-capture
Disclosure: we built 8D Gate, a free advisory pre-send check for 8D reports.
Advertising
why am I receiving an ad masquerading as an article as the lead item?
