Multivariate Charts
When you see how they work, you’ll see why they don’t work
Susan Holt Simpson / Unsplash
SPC Press
Mon, 08/24/2026 - 12:03
Some of my colleagues have recently been pushing multivariate charts. These charts combine several different process outcome values into a single number that’s placed on a chart. Unfortunately, this theoretically elegant approach breaks down in practice for reasons that will be explained here.
We shall use the example of Adhesive 442 to illustrate the ideas behind multivariate charts. Each batch of Adhesive 442 is characterized by two key properties, pH and viscosity. Twenty consecutive batches had the values shown in Figure 1.
Figure 1: Adhesive 442 data
The average pH for Adhesive 442 is 7.9825. The average moving range for the pH values is 0.221. Based upon this value, the sigma(X) value for pH is 0.196. The XmR chart for the pH values is shown in Figure 2.
Figure 2: XmR chart for Adhesive 442 pH values
Submitted by Bev Daniels (not verified) on Mon, 08/24/2026 - 10:20
Multivariate is not Multi-Vari
These two terms do get confused even by statistical software.  Let’s be clear that the multi-vari chart (as first advocated by Leonard Seder) is a simple uncomplicated graphical study that displays all raw data without any mathematical manipulation.  It is very useful for Problem Solving and I’ve used it as a basis for determining rational subgroups.  It is not the thing that Dr. Wheeler discusses.
Submitted by Donald J. Wheeler on Mon, 08/24/2026 - 14:06
In reply to Multivariate is not Multi-Vari by Bev Daniels (not verified)
Reply for Bev Daniels
Thank you Bev for your comment.  Yes, you are right.  Although somewhat subjective, Multi-Vari plots are based on the same principle as process behavior charts.  They use the power of the graph to make changes visible.
Submitted by Jim L. (not verified) on Fri, 08/28/2026 - 04:20
Multi-vari examples?
Where would I find examples of multi-vari charts? Do you have any you can share?
Submitted by dangermoney on Mon, 08/24/2026 - 11:39
<p></p>
Submitted by Sergey Grigoryev on Mon, 08/24/2026 - 12:08
Another brilliant article by Donald Wheeler
The article once again confirms the core principle I follow in my work: the best analysis is the simplest one that provides the necessary understanding of the process.
Submitted by Ekim Recrem (not verified) on Mon, 08/24/2026 - 16:23
www.PBCharts.com
We built an Excel Add-In to make process Behavior Charts and named it in honor of Donald Wheeler. Here is an example of the charts of pH and Viscosity.
See it at https://peltiertech.com/Image removed.pbcharts
