What Is the Penalty in Being Wrong?
More on the use of Cp and Cpk
Scott A. Hindle
Manufacturing specialist
Wed, 10/19/2016 - 16:10
In all walks of life, being wrong can come with a penalty. It’s also true that, if you’re lucky, you sometimes get away with it without anybody being the wiser. To understand what this means in relation to the capability indexes Cp and Cpk, read on.
Introduction
In part 3 of “Process Capability: What It Is and How It Helps,” I wrote regarding the interpretation of the two most commonly used capability indexes:
• Predictable processes: Cp and Cpk can be considered reliable indicators of future performance.
• Unpredictable processes: Cp and Cpk may be false, or very misleading, indicators of what the process will give in the future.
Why Remote Work Isn’t Working
Submitted by mfmatusky on Wed, 10/19/2016 - 20:12
Capability Indicies
The use of tools like a one sample t test is impressive but the whole debacle would have been revealed immediately if the individuals chart had been the FIRST thing done
Submitted by Scott A. Hindle on Tue, 02/01/2022 - 00:07
In reply to Capability Indicies by mfmatusky
Your comment
Fully agree. The quote synonymous with Ellis Ott comes to mind "PLOT THE DATA" (https://www.qualitydigest.com/may07/articles/05_article.shtml). Most data have a time component so a simple time-series plot assures the kind of silly mistake made above with Cpk wouldn't happen in practice.
Submitted by mfmatusky on Tue, 02/01/2022 - 12:12
Cp/CpK and Pp/Ppk; Rational Subgroups
Hey Scott-  Another detail that often goes unmentioned is the topic of rational subgroups.  Generally speaking, Cp and CpK are calculated using an Rbar over D2 or an Xbar over D4 approximation of the sample standard distribution.  This makes sense if the data is collected in rational subgroups.  What makes up a rational subgroup?  Not the setting on the statistical software!  They are inherent in the data collection.  If an established sample size is collecteded each time samples are measured rational subgroups are established.  They cannot be "created" after random data is recorded.
The use of rational subgroups enforces the assumption that the process is under control; variation within subgroups is considered while variation between subgroups is essentially ignored.
The alternate indicies, Pp and PpK should also be considered.  In these indicies the sample standard deviation is the actual value based on individual measurements.  All variation is considered.  One benefit of considering Pp/PpK along with Cp/CpK (which again can only be used if the data is collected in rational subgroups!!) is that individual outliers can be set aside.  When one "Plots the Dots" there may be obvious outliers from otherwise in-control data.  The special causes of the outliers can be sought (and hopefully eliminated!) while the otherwise in control process can be left alone and untampered with.
