Handheld Pressure Calibrators for Hazardous Areas
JOFRA HPC550Ex and HPC552Ex offer deadweight accuracy for on-site or field use
AMETEK
Thu, 05/19/2011 - 10:48
(AMETEK Calibration Instruments: Largo, FL) -- The new JOFRA HPC550/HPC552Ex family of handheld pressure calibrators from AMETEK Calibration Instruments offer deadweight accuracy and are rated intrinsically safe for potentially hazardous locations.
The HPC550/HPC552Ex bring laboratory accuracy to an on-site, field-usable instrument and are well suited for a broad range of applications, from simple tool type jobs to complex calibration applications in custody transfer systems. The calibrators offer a full set of intelligent features, including user-configurable information display, 15 different pressure units, transmitter supply, mA input, percent-error calculation, voltage measurement, serial communication, and external pressure module.
Why Remote Work Isn’t Working
Run It Past the Murder Board
Submitted by nagman on Fri, 03/30/2018 - 01:05
Instrumentation and Pressure Calibration
Hand-held measuring instruments to include the model CPH6510 intrinsically safe pressure calibrators. With an accuracy of 0.025 % of span and various additional functions, the new instrument is suited to a wide range of applications, and due to its ATEX approval, these also include hazardous areas.
The new hand-held is available with either one or two built-in reference pressure sensors. This allows 24 different measuring ranges of up to 700 bar to be covered. In addition, the CPH65I0 accepts transmitter output signals (0 ... 24 mA) and the ambient and medium temperature (-40 ... +150 °C) is measured by a resistance thermometer. A pressure switch test function completes the functionality. Thus users can calibrate all types of pressure measuring instruments with the new calibrator.
Although it is multi-functional, the robust CPH65I0 is simple to operate using just three keys. On the five-digit, backlit display, three measurement parameters can be displayed simultaneously. The battery power supply is designed for at least 35 hours of operation.
