All Those Datum Things
Smart GD&T workshop No. 5
William Tandler
Wed, 02/13/2008 - 22:00
As we know, GD&T is a symbolic language with which to specify permissible limits of imperfection in manufactured parts, namely limits that maximize the parts’ operability, assemblability, and affordability. It’s complex only to the extent that the real world of imperfect geometry is complex. If we’re dealing with a slightly tapered, slightly bent, slightly tilted, and slightly offset shaft, which is supposed to fit into a slightly, equally distorted mating bore, we need concepts, tools, and rules that can address those details. That’s GD&T.
The less clearly we deal with the concepts, tools, and rules of GD&T, the more complex and confusing the subject becomes, making it necessary to interpret poorly framed verbal statements and badly stuffed feature-control frames, instead of being able to simply decode clear statements and properly encoded feature control frames. Therefore, crystalline concepts, tools, and rules are essential to make GD&T work, and are the only way to turn the jungle of GD&T into a well-laid-out, formal garden.
The world of datums
The many concepts associated with the word “datum” represent a particularly important part of this jungle—oops, garden—and our purpose in this workshop is to define them so clearly that we can use them with confidence and communicate them clearly.
We’ll deal with these concepts in the following order:
Submitted by Fabiola Córdova on Fri, 07/28/2017 - 12:13
Questions
Hi Mr William
I have one questions. In this case i have the compound datum, how use these informations for doing the program or interpret it?
These datums are not in the same dimensions.
Datum A (Primary)
Datum B ( Second)
And Datum C-D (Compound datum).
This information is the unique i have.
Thanks for you help
Any question let me knows
Best Regard
Ing. Fabiola C.
