In my last column, I showed how hidden special causes can sometimes create the appearance of common cause, but the purpose of common-cause strategies is to deal with this and smoke them out. When there's an underlying structure to how these data were collected, or when one can somehow code each individual data point with a trace to a process input, stratifying the data accordingly can many times expose these special causes.
| ADVERTISEMENT |
Even the simple coding of individual points on a graph can be every bit as effective as the more formal tool of a stratified histogram. I’m going to take the issue of understanding variation in count data further in the next couple of columns. I’ll begin here by looking at two scenarios.
Ban The Phrase "Trend Line" From Business!!!
Cause & Effect Diagram
What's wrong with using a C&E diagram to deal with common causes?
I find them very useful.
Rich D
"Vague"
If you want to do a HUGE Ishikawa diagram brainstorming "What causes medication errors" or "What causes accidents," be my guest.
I'd rather do a high-level stratification FIRST to find out the 20% of the process causing 80% of the problem first, THEN doing an Ishikawa diagram.
Three sources could get exposed: (1) a certain department ALREADY DOING GOOD WORK could have a problem with one particular medication/accident type (due to a unique input), (2) certain departments might have an OVERALL problem with their "safety" or "medication prescribing" process, and (3) there might be certain accidents or error types that are being made by EVERYONE -- which would be a system problem. These will be far more FOCUSED issues.
Plus...to dicover this, you will have to collect a lot LESS data than what would result from a huge Ishikawa no doubt implementing "vague" ideas suggested by "good people"...and getting "vague" results...and making a lot of people mad in the process.
If this makes you feel any better, Mea culpa! I learned the above from Joiner's brilliant "Fourth Generation Management" book...and I'm making a lot fewer people mad these days by not wasting their times collecting data that doesn't ultimately help them or anyone else.
More about that in my next article...
Thanks for reading.
