Flu Season Readiness Starts With Standardizing Equipment Management
The strongest plans aren’t built around a bigger inventory
Wonderlane / Unsplash
Andrew Yamarick
Agiliti
Thu, 11/12/2026 - 12:02
Flu season arrives every year, but its effect is never entirely predictable. Patient volumes can rise quickly, respiratory cases can require specialized equipment, and hospital teams already stretched thin must respond without compromising care. In that environment, readiness depends on more than a hospital’s equipment inventory. It requires that the right equipment is accessible, maintained, and patient-ready at the moment it’s needed.
That’s where many hospitals encounter a persistent challenge. Healthcare has rigorous standards for clinical care, safety, and compliance, yet the day-to-day management of medical equipment often remains fragmented and inconsistent. Responsibilities might be divided among nursing, clinical engineering, environmental services, and supply chain, with each team relying on different processes and systems to track and manage device types and inventories. Those gaps create inefficiency, drive up costs, and lead to operational and clinical bottlenecks.
The difference between ownership and readiness
A hospital may own enough infusion pumps, beds, monitors, or ventilators on paper and still struggle to locate a patient-ready device. Equipment might be awaiting cleaning, overdue for preventive maintenance, held on a unit “just in case,” or sitting in a repair queue. Without a shared view of inventory, location, and status, an apparent shortage could be a visibility problem rather than a true lack of equipment.
These breakdowns become more consequential as the patient census surges. Caregivers spend time searching for devices, biomedical technicians work through growing maintenance backlogs, and supply chain leaders make rental or purchasing decisions without reliable use data. The result can be slower patient throughput, excess capital spending, and valuable clinical time diverted to nonclinical work.
Why third-party service providers matter
Specialized medical equipment partners are built to manage this complexity across facilities, device types, and periods of changing demand. They can provide a common operating layer among functions that are often siloed inside the hospital.
This creates four practical advantages during periods of peak volume or specialized patient need.
Flexible capacity: Hospitals can own equipment for predictable baseline demand and use supplemental device rental or other flexible access models for seasonal variability, specialty needs, and unexpected census spikes. This avoids the cost of buying, storing, and maintaining enough equipment for every possible surge while preserving access when demand changes.
Standardized readiness processes: A third-party partner can apply consistent cleaning, inspection, preventive maintenance, and documentation workflows throughout sites. That consistency reduces variation by facility, technician, or shift, and it gives leaders greater confidence that “available” also means patient-ready.
Better visibility and use: Centralized tracking and onsite equipment management can give nursing, clinical engineering, and supply chain a shared view of inventory, location, and status. Reliable use data help leaders distinguish between real shortages and equipment inventory that is simply idle, misplaced, or in need of service.
Additional people and expertise: Seasonal demand affects equipment and labor at the same time. External biomedical technicians, logistics teams, and credentialed equipment specialists can help hospitals address repair backlogs, augment coverage through holidays and staffing shortages, and remove equipment-related workload from clinicians so they can spend more time with patients.
From reactive response to a planned operating model
The greatest value of a third-party partner comes before the surge, not after it begins. Hospitals can use the weeks ahead of flu season to audit equipment availability, identify overdue maintenance, validate PAR levels, and determine which devices should be owned, shared, rented, or supplemented through outside support.
A practical model combines internal and external capabilities. Hospitals maintain the assets and teams required for steady-state demand, while third-party partners add supplemental equipment, technical support, logistics, and onsite management where scale or variability would make an internal-only model less efficient. Throughout a health system, that same partner can also help move equipment between facilities and apply consistent standards rather than allowing sites to operate differently.
This approach turns surge readiness into an operating model rather than an emergency purchase. It gives hospitals options when demand rises, and it reduces the need to choose between overbuying equipment and scrambling when census exceeds expectations.
What hospitals should put in place before volumes rise
Four actions can help strengthen flu season readiness:
1. Establish one shared view of equipment inventory, location, maintenance status, and patient readiness for nursing, clinical engineering, environmental services, and supply chain.
2. Complete a preseason audit of high-demand equipment, preventive maintenance backlogs, repair capacity, and expected PAR levels.
3. Use utilization and demand data to define what equipment should be owned to meet baseline needs and what it should access through rental, shared pools, or other flexible models.
4. Confirm that third-party equipment, service, and logistics partners have clear escalation paths, local response capabilities, and agreed-upon readiness standards before demand increases.
The standard is patient-ready access
Flu season doesn’t create equipment-management gaps, but it makes them harder to ignore. Hospitals operate more effectively during a surge when they have a consistent model for managing equipment they own and accessing the equipment they need.
Third-party medical equipment partners help make that possible. By combining supplemental equipment, technical expertise, standardized workflows, onsite support, and systemwide visibility, they enable hospitals to respond to changing demand without carrying every capability and every asset internally.
The strongest flu season plans aren’t built around a bigger equipment inventory. They’re built around a standardized and dependable operational system where lifesaving equipment is always available and patient-ready.
Why Remote Work Isn’t Working
Run It Past the Murder Board
About text formats
