Eight Dumbest 3D Printing Mistakes: FFF Edition
You’ve probably made all of them
Kerry Stevenson
Wed, 11/02/2022 - 12:02
Operating a desktop FFF 3D printer can be a ton of fun, except when you make mistakes. Mistakes can cause print failures, and also embarrassment when they are so obvious you really should not have made them.
Let’s take a look at my list of the eight dumbest FFF 3D printing mistakes you can make.
Mismatched filament
Symptom: “Why is there no extrusion? Is there a jam?” No, it’s because you’re trying to print a higher-temperature material like ABS or ASA when you’ve sliced the job for PLA temperatures.
Cause: This is a common mistake caused by forgetting to select the proper material when slicing a print job. It’s easy to focus on other parameters and forget to match the slicing material to the actual spool on the machine.
Solution: Always double-check the spool type and slicing material.
Forgetting support structures
Symptoms: “Why is this print all spaghetti?” “What happened to the underside of the protrusion?” “The print just failed, and I don’t know why.”
ISO 9001:2026 Is Here
