The Environmental Monitoring Gap Your QMS Isn’t Closing
Your system can be compliant, but wrong
Grispb/Adobe
Aity Ritesh Raj
Mindlabs Cloud
Mon, 06/29/2026 - 12:03
FDA inspectors don’t just check your records. They bring their own thermometer.
And when their reading doesn’t match six months of logged data from the sensor on your cold room wall, the honest explanation is one nobody wants to say: The monitoring system was compliant; the measurement just wasn’t accurate anymore.
I know because I’ve been in that room.
Working across pharma cold chains and GMP storage facilities in India, I’ve seen this scenario play out more than once—a fully connected, cloud-logged, 21 CFR Part 11-compliant monitoring system sitting confidently on a dashboard while the actual cold room temperature tells a different story. The system isn’t broken; the data are wrong. And the gap between those two things is what this article is about.
Two promises. One assumption.
A 21 CFR Part 11-compliant data logger makes exactly one promise: The data it captures will be tamper-proof, time-stamped, and audit-ready. That’s a data integrity commitment. A good one.
Why Remote Work Isn’t Working
ISO 9001:2026 Is Here
Submitted by Carig Cochran (not verified) on Tue, 06/30/2026 - 08:18
Concise process for oversite of cold rooms
This practical and concise article outlines exactly the way cold rooms should be monitored by the QMS. Well done.
