You can’t brainstorm your way out of organizational problems
nathan kosmak/Unsplash
Susan Robertson
Mon, 11/16/2026 - 12:03
A manufacturer knew something was wrong with its innovation process. Ideas moved slowly. Priorities weren’t always clear. Different parts of the business had different views of how projects were supposed to move. So, the obvious conclusion was that the innovation process needed to be fixed—a reasonable diagnosis, except it wasn’t quite right.
When people from across the organization came together in a workshop to map how innovation happened, the process problems were easy to see. But something more interesting surfaced alongside them. Some projects lacked clear ownership. Resources sat in parts of the business with competing priorities. Strategic criteria for choosing among ideas weren’t always obvious. Different functions saw only their piece of the system.
The company did have an innovation problem. It just wasn’t only an innovation problem. And that distinction matters.
We tend to fix what we can see
When organizations struggle with innovation, they usually reach for innovation solutions. Not enough ideas? Run a brainstorming session. Ideas aren’t very good? Teach people creative thinking. Projects are moving too slowly? Tighten project management.
None of those is necessarily a bad response. But they all assume the visible problem is the real problem. Sometimes it isn’t.
More ideas won’t fix a system that can’t move the ideas it already has. Better brainstorming won’t solve unclear decision rights. More creativity training won’t create capacity for people who are already overloaded. And stronger project management cannot compensate for a project nobody truly owns.
The symptom usually shows up downstream
One reason these problems are so easy to misdiagnose is that the place where something breaks is not necessarily the place where the problem began.
A project stalls in technical development, so it looks like a technical bottleneck. But perhaps nobody made a clear strategic choice about which projects deserved priority. A team appears resistant to a new initiative, but perhaps no work was removed to create capacity for it. A portfolio looks scattered, but perhaps the organization has never translated business strategy into clear criteria for deciding which opportunities matter most.
By the time the problem becomes visible, the real cause may be several steps upstream.
And once we give a problem a label, that label starts shaping which solutions we consider. Call it an innovation problem, and we look for innovation fixes. But the label can become a set of blinders. Sometimes the first mistake happens before anyone tries to solve the problem: We name it too quickly.
This isn’t just a big-company problem
Complex global organizations certainly have more boxes on the org chart. But smaller organizations can create exactly the same dynamics with fewer people.
Imagine a 40-person manufacturer where the same engineer responsible for new-product work is also the person everyone calls when production goes sideways. Or a family-owned business where new opportunities are encouraged, but every meaningful decision still has to pass through one overloaded owner. The structures might be more informal, but the consequences are similar.
When something important repeatedly stalls, visionary organizations resist the temptation to immediately fix the thing that appears broken. Instead, they get curious about the system around it.
Three questions can reveal a lot
1. Where does the work actually stop? Take one real idea, project, or initiative and follow it from beginning to end. Not the official version of the process; the actual one.
Where does momentum disappear? Does it reach a point where nobody knows who moves next? Does it wait for a decision from someone who has little visibility to the work? Does it arrive in a department with no capacity to take it on?
The answer matters, because the location of the pain may not be the location of the problem. If projects consistently stall at the same point, don’t just push harder there. Look upstream. Something may be causing that bottleneck.
2. What is the system asking people to optimize for? When people repeatedly behave in ways leadership doesn’t want, it’s tempting to assume they need different attitudes, more accountability, or stronger motivation. Sometimes they do. But persistent behavior is often a systems clue.
Look at what people are responsible for. What gets measured? Who controls their time? Where does their budget sit? Which decisions can they make on their own?
Then ask a simple question: What behavior makes sense inside this system?
If the leaders say one thing matters, but the structure makes something else easier, safer, or more rewarding, people usually respond to the structure. That’s not necessarily resistance. It might simply be rational behavior given the environment.
3. Who sees the whole picture? Innovation usually crosses boundaries. Sales understands what customers are asking for. Marketing sees market shifts. Technical teams understand feasibility. Operations understands what it will take to produce. Leadership sees strategic priorities.
All of those perspectives matter, but somebody has to see how they connect. Without that view, each function can make a perfectly sensible local decision that unintentionally slows the larger system.
This doesn’t require a fancy new title or another layer of management. In a smaller company, it might be one person with explicit responsibility for the full flow. In another organization, it might be a cross-functional leadership team or a regular portfolio review. The mechanism matters less than the outcome: Someone has to own the whole picture.
Diagnose before you prescribe
The manufacturer in the story above did need a better innovation process. But redesigning the process alone would never have been enough. The deeper work was recognizing where ownership, capacity, priorities, structure, and decision-making had become tangled around it. That’s the more important lesson.
When an organizational problem persists despite repeated attempts to fix it, the answer may not be another tool, another meeting, or another push for accountability. The visible problem may simply be where the system finally shows its strain.
Visionary organizations look beyond the symptom, because the fastest way to solve the wrong problem is to name it too quickly.
Submitted by Dirk van Putten (not verified) on Mon, 11/16/2026 - 10:44
Great Article - Systems Thinking
What a great article! Look at the business as a set of inter-related processes. A system. I especially appreciated the paragraph about labeling or naming. Once we label a thing or a person, we begin to prescribe values, positions that affect how identify ourselves or things.  Finally, nice set of three questions. Thank you for sharing this article.
About text formats
