Leak-Master Easy Plus Delights Quality Inspectors
All the advantages of water-bath testing with all the advantages of digital control
Wed, 03/17/2021 - 12:00
(Witt: Witten, Germany) -- Witt has further optimized its leak tester “Leak-Master Easy Plus.” These popular leak testers which generate digital documentation from their water bath tests, are now even more convenient to use.
The test method in a water bath is particularly uncomplicated, cost-effective, and has the advantage that a weak point in the packaging is clearly visible as air bubbles rise to the water surface in the event of a leak. In many cases, this error localization makes it possible to optimize the packaging or manufacturing process and thus reduce the error rate.
The “Leak-Master Easy Plus” offers the ideal combination of all the advantages of water bath testing with the rich possibilities of digital control. With this, the quality manager can predefine standardized test programs and electronically record and document all the data from the leak tests as performed. If required, the testing device can even be integrated into a wider network.
The new high-resolution touch display and the new user interface offer an even clearer and more intuitive user-friendly menu navigation, perfecting the inspection process and the documentation of the measurement results for the quality inspector.
Why Remote Work Isn’t Working
ISO 9001:2026 Is Here
