AW-Lake Expands Product Line With TH Series High-Accuracy Turbine Flow Meter
Laboratory-grade performance in a rugged, field-ready package
Thu, 03/05/2026 - 12:03
(AW-Lake: Oak Creek, WI) -- AW-Lake, a flow instrumentation manufacturer, announces the launch of its TH Series high-accuracy turbine flow meter, a precision liquid flow measurement solution for demanding industrial applications in which every fraction of a percent matters.
Precision machining, tight internal tolerances, and stainless-steel construction provide stable, long-term performance in continuous operation. Designed for low-viscosity liquids such as oils, water, and many process chemicals, the TH turbine meter delivers laboratory-grade performance in a rugged, field-ready package.​
AW-Lake high-accuracy turbine
High measurement accuracy
Measuring accuracy is specified to ±0.5% under controlled conditions with linearization, with repeatability as tight as ±0.1% for high-confidence flow control.​
This accuracy supports critical operations such as batching, dosing, blending, and test stands where even small deviations can create scrap or off-spec product.​
ISO 9001:2026 Is Here
How to write an SOP
