Your Measurement System Doesn’t Know Where It Is
Geometry, pose, calibration state, and confidence need to travel with the reading
Mohanad Fors/Unsplash
Joshua W.J. Brown
Thu, 09/24/2026 - 12:03
A measurement isn’t only a number. It’s a number obtained by an instrument in a physical state.
That distinction becomes critical when the instrument moves, bends, conforms to a surface, or relies on software to correct its own geometry. A rigid gauge can often treat its working geometry as a stable calibration condition. A flexible array, robotic probe, or articulated inspection head can’t make that assumption.
The practical quality lesson is simple: If geometry can change the result, geometry belongs in the measurement record.
Ultrasonic inspection makes the problem clear. In air-coupled ultrasonic testing, the transducer and the part are separated by air rather than water, gel, or direct mechanical coupling. That can be useful when contamination, moisture, or direct contact is undesirable, but the acoustic penalty is severe. The air-to-solid interface reflects much of the incident acoustic energy, so usable measurements depend strongly on controlled geometry and signal processing.
