(Physik Instrumente: Shrewsbury, MA) -- Last October in San Francisco, Physik Instrumente (PI) displayed a variety of high-precision motion systems based on magnetic levitation technology at SEMICON West 2026.
This advanced technology enables active six-axis control without any restrictions from traditional bearings. Each stage levitates and directly actuates its moving platform, eliminating mechanical bearing contact, lubrication, and bearing wear. Target applications include hybrid bonding and advanced packaging, wafer inspection, and high-resolution surface metrology.
Long-travel linear stage: Force-controlled bonding and inspection on the fly
The linear demonstrator integrates 400 mm of travel in X, 400 µm in Y and Z, and angular motion of 1 mrad in θX/θY and 2 mrad in θZ in a single levitated body, with in-position stability below 2 nm in Z and below 20 nrad in angle. It supports a constant-velocity Z approach with contact detection, then applies process forces for bonding above 100 N with mN force resolution. The stage achieves 2 g acceleration and 400 mm/s; other configurations support up to 6 g.
Rotary wafer stage: Unlimited rotation with active plane control
The rotary demonstrator pairs unlimited θZ travel and speeds above 600 rpm with active control of the rotor center and plane. Axial position and tip/tilt are stabilized throughout rotation, holding axial error below 5 nm and tilt error below 50 nrad peak to peak to maintain the measurement plane during wafer inspection and metrology. Payloads up to 25 kg are possible with other configurations.
AFM scanner: Picometer resolution over millimeter ranges
The MagLev AFM scanner combines piezo-class resolution, 50 pm or better in X/Y, and 100 pm or better in Z, with 12.1 mm of X/Y travel, supporting die-level profiling without stitching. Other configurations can extend X/Y travel to 50 mm.
Why active 6-axis control matters
Magnetic levitation nanopositioning systems replace mechanical bearings with actively controlled magnetic fields, eliminating friction, wear, lubrication, and bearing-related particle generation. Active six-axis control also allows positioning and alignment errors to be corrected electronically within a single motion platform, reducing the need to stack multiple mechanical positioning stages.
Applications and industries served
• Semiconductor manufacturing
• Advanced packaging and hybrid bonding
• Wafer inspection
• High-resolution surface metrology
• Optics and photonics
More information at PI Maglev Technology.
100% bearing-free: Six axes, zero contact. PI’s MagLev platforms show promise for hybrid bonding and wafer metrology.
