It’s one of the most dangerous sentences you can hear on a factory floor: “The drawing is updated, and we’re good to go.”
It sounds like the finish line. We fixed it! Nothing else to do here.
I’ve watched this play out countless times in different hardware teams. A part caused a headache on the assembly line. The engineering team swoops in, does a root-cause analysis, and edits a tolerance. They move a hole pattern by a millimeter or change a material. The CAD model gets updated, the new drawing is released, and everyone is happy. The engineering problem is solved.
So they kick off the next production run. And then the wheels fall off. Again.
A supplier had still blindly churned out the old revision. Quality control was inspecting an outdated print. The operator on the floor is looking at work instructions that no longer make physical sense, and so on. You get the point.
The engineering team fixed the part, but they didn’t think about the factory.
