5 Essential Elements Shared by Leading Supplier Quality Management Systems
Manage risk effectively with quality controls in place
Arno Senoner / Unsplash
Stephanie Ojeda
AssurX
Thu, 08/21/2025 - 12:03
Global-scale events have tested the bounds of supply chain systems. The coronavirus, for example, made it clear how critical an efficient supply chain is for continuity and survival. It’s a real-world example of how important it is to have an enterprisewide system that uses a quality management system (QMS) as the hub of truth.
Organizations that demonstrate poor control of supplier quality management (SQM) are likely struggling to manage risk effectively. Poor controls can result in audits, warning letters, injuries, recalls, and negative revenue.
This article looks at five common traits that, together, can enable high-performing supplier quality management practices in regulated industries.
3 Things You Should Never Say When Presenting
