Your Transactions Are a Process, Too: SPC Beyond the Shop Floor
Transactional processes leak money in quantities that would end careers if the leakage were visible as scrap
Framestock/Adobe
Mani Chandra Raparla
Contrint
Thu, 09/17/2026 - 12:02
Walk any well-run plant and you’ll find statistical process control doing quiet, faithful work: control charts on the critical dimensions; capability studies before a line change; gage R&R before anyone trusts a measurement; out-of-control signals investigated; root causes found; corrective actions closed. Quality professionals built this discipline over 70 years, and manufacturing is incalculably better for it.
Now walk 50 feet from the shop floor into the office where the orders, receipts, invoices, and credits are processed, and ask a simple question: Where are the control charts?
There are none. The transactional side of the same enterprise, the processes that turn shipped product into collected cash and received material into paid invoices, runs with less statistical oversight than a single CNC spindle. And here’s the uncomfortable part for those of us who came up through the quality profession: The transactional processes are producing defects at rates no production manager would survive, and nobody is charting them.
The defects nobody charts
Let me be concrete about what a transactional defect looks like, because it’s not a typo in a spreadsheet.
A delivery ships complete and on time, a triumph of the physical process. Then no invoice is ever generated, because a master data attribute quietly routed it out of the billing run. Material is received against a purchase order, inspected, accepted, and put away, and the supplier’s invoice never arrives, so an open liability sits on the books for 300 days. A customer return is processed flawlessly on the logistics side, and the credit memo that should follow never gets created.
Each of these is a nonconformance in every meaningful sense: The process failed to produce its specified output. But notice what makes them different from a shop-floor defect. There’s no scrap bin. There’s no part to inspect. The defect is a document that doesn’t exist, and our entire inspection tradition, from incoming inspection to final audit, is built on examining things that do exist. An absence passes every inspection ever devised, because it never shows up for one.
The financial consequence compounds quietly. An unbilled delivery is revenue earned and never collected. An uninvoiced receipt is a liability with no owner. In the plants I’ve worked with during 15 years of ERP implementations, the accumulated value of these silent nonconformances routinely reaches sums that would trigger a stop-ship if they appeared as physical scrap.
Why the discipline never crossed the 50 feet
Quality professionals didn’t ignore transactional processes out of negligence. Three practical barriers kept SPC on the floor:
The first was measurement. Shop-floor SPC works because measurements exist: a caliper reading, a test result, a count. For decades, transactional processes had no equivalent measurement system; the data lived scattered across modules, and assembling them meant a manual project nobody commissioned.
The second was sampling logic. Classical SPC grew up under the economics of sampling. Measuring everything was impossible, so we developed rational subgroups and sampling plans. Transactional data seemed to belong to a different world, the world of accounting, where completeness is assumed rather than tested.
The third was ownership. The quality function owned the product; finance owned the documents. The processes in between, where a delivery becomes an invoice, sat in the seam between two professions—and seams belong to nobody.
All three barriers have quietly collapsed. Every transaction in a modern ERP is a time-stamped, quantified, statused measurement, recorded automatically at population scale, no sampling required. The measurement system quality professionals lacked for 70 years now runs itself, all day, as a byproduct of operations. What hasn’t caught up is us: The profession’s habits, charts, and attention are still standing 50 feet away.
There’s a fourth force worth naming: scarcity. The people who master statistical thinking are few and expensive, so organizations ration their attention, dispatching them to whatever is currently loudest. The transactional office never screams. It just leaks.
What quality thinking brings that finance doesn’t
Someone will object that finance already audits the books. True, and the objection misses what our profession uniquely knows.
Audits are inspection, and we’ve known since Deming that you don’t inspect quality into a process; you build it in and control it statistically. An annual audit that catches last year’s unbilled deliveries is final inspection at its least useful: late, sampled, and after the loss. What the transactional world lacks is precisely what SPC provides: continuous monitoring of process behavior, signals when the process drifts, and the discipline of root cause rather than case-by-case correction.
Root cause thinking matters enormously here, because transactional defects cluster the way physical defects do. When deliveries stop billing, it’s rarely random; a single wrong master data attribute, one bad setup in the process, silently routes every affected transaction into the same failure mode, exactly like a worn tool cutting every part under size. Fix the case, and the defect returns tomorrow. Fix the attribute, and the failure mode is gone. Any Black Belt recognizes this instantly. Most finance teams, trained to resolve items rather than chart processes, don’t.
One caution from hard experience, offered in the spirit of Gage R&R: Before trusting any measurement of transactional processes, validate the measurement system itself. Transaction histories contain reversals, corrections, and legitimate exceptions, and naive analysis that flags every artifact will produce false alarms. And false alarms, as every quality professional knows, are how monitoring systems lose the trust of the people they serve. The standard is the same one we hold control charts to: A healthy process should produce a quiet chart.
The barrier still standing: What inertia actually looks like
If the measurement barrier has collapsed and the methods are proven, why has the profession not already crossed the 50 feet? The honest answer is inertia. Inertia inside an organization isn’t laziness. It has specific machinery, and it’s worth naming the parts.
The first part is budget structure. Quality budgets are scoped to the product, because that’s what quality was chartered to protect when the charters were written. Transactional process control has no cost center to live in. Finance funds transaction processing, not transaction measurement, and quality funds the plant. A project that belongs to everyone’s benefit and nobody’s budget line doesn’t get funded, however good the mathematics.
The second part is incentive design. Organizations reward visible rescues over invisible prevention. The engineer who resolves a stop-ship is a hero by Friday; the analyst who catches a billing drift on Tuesday, before it becomes a quarter of unbilled revenue, has prevented a crisis nobody ever saw and receives credit in proportion to its visibility, which is none.
Firefighting is promoted. Fire prevention is assumed. Every quality professional has lived this asymmetry on the shop floor; it’s even stronger in the office, where the fires themselves are invisible.
The third part is rhythm. The audit calendar, the quarterly review, the annual assessment: All were designed in the era when assembling data was the project, and they survived the constraint they were built around. A monthly review of transactional health made sense when the measurements took a month to collect. The measurements now exist continuously, and the rhythm hasn’t noticed.
None of these mechanisms is irrational. Each made sense when it was set. Together, they keep enterprises inspecting continuous processes episodically, decades after the original constraint disappeared. This is what inertia looks like up close: not resistance to change, but structures faithfully solving a problem that no longer exists. It’s the one nonconformance no control chart will ever flag, because it lives in the budget cycle and the org chart, not in the data.
The invitation
The quality profession has spent decades proving that statistical thinking, applied with discipline, transforms any process it touches. The transactional processes of the enterprise have inputs, outputs, specifications, failure modes, and defect rates. They generate better measurement data than the shop floor ever did. And they are leaking money in quantities that would end careers if the leaks were visible as scrap.
The 50 feet between the shop floor and the transaction is the shortest distance in the enterprise, and the least traveled by our profession. The barriers that once justified the distance are gone; only the machinery of habit remains, and machinery can be redesigned.
Cross it, bring the charts, and ask the question no one in that office has ever been asked: Is this process in control? The answer, in my experience, will keep a quality team busy for years. And the findings, for once, will be denominated directly in dollars.
About text formats
