How JTEKT Made Standard Work Stick
The people who can do it are often the hardest layer to reach
RONNAKORN TRIRAGANON / Unsplash
James Glover
Flint Learning Solutions
Mon, 11/30/2026 - 12:03
Last fall, production engineering at a JTEKT North America plant fixed a problem with a straightener. That’s about as ordinary as plant news gets. What makes it worth a closer look is the route the problem took to reach the engineers.
An operator mentioned that flash (a thin ridge of excess material) on parts was slowing production. The team lead wrote it down, and when the complaint came back, he wrote it down again. His supervisor saw the pattern, traced it to the straightener, took it to the plant manager, and brought in engineering.
That’s how every plant is supposed to work, and anyone who has run one knows how often it doesn’t.
Whether a complaint climbs the plant or dies at the workstation depends on the team leads and supervisors who can escalate it. On a line where standard work separates hitting cycle time from pushing a defect downstream, every complaint that dies with them may show up later as a slow shift or a customer return.
JTEKT North America, which builds steering systems, driveline components, and bearings in 10 plants, set out to develop both levels on the floor at the same time, and measured whether their behavior changed.
Where they started
Frontline leaders are among the least-developed people in any plant. In a 2025 PwC and Manufacturing Institute survey of manufacturing leaders, more than half said they offer role-specific development to frontline leaders only once a year; nearly one in five never do.
At JTEKT, before launch, each participant and their manager independently rated the same behaviors. Team leads were at or below expectations on documenting defect responses against standard work, on taking ownership during 5S walks, and on following through on their own commitments. Supervisors tended to solve problems themselves instead of coaching team leads through them. The lowest rated behavior centered around the floor management development system (FMDS), the daily management board on the floor, where actions often had no clear owner or realistic date. This isn’t ideal, but it’s a realistic situation for many manufacturing facilities in multiple industries.
What JTEKT ran
Over 10 weeks, 73 team leads and supervisors at four plants practiced through short activities during production. The activities were tailored by role, because enforcing standard work looks different depending on where you stand.
Team leads, who face the operators, used the daily 5S walk to pick one area that wasn’t right and fix it with the team. They checked in with struggling team members to write down what was in their way.
Supervisors, who face the system, mentored team leads through FMDS analysis and documented root causes and countermeasures in the shift abnormality log.
A typical activity read like this: On your next 5S walk, pick one area that isn’t right. Show your operators what “organized” looks like, and fix it together before the line restarts.
One team lead reported back: “During our 5S audit, I noticed that our offline area had an unorganized workspace that could have led to changeover parts being mixed by mistake. I demonstrated what the organized workspace should look like and made the technician correct their mistake.”
It wasn’t revolutionary, just intentionally practicing the right behaviors during a sustained time period. Each activity took less than a minute to understand and was done on the floor, during the shift, then debriefed. Participants completed more than 550 activities in less than six minutes per participant per week.
Why the chain held
So was the straightener fix a matter of luck?
The timing says otherwise. The team lead who documented the flash was checking in with a struggling team member, and his supervisor was working a parallel activity during the same weeks. So when the team lead wrote the problem down a second time, the person above him was already practicing what to do with it.
A second chain started with a standard work change that was confusing technicians and causing short stops. A team lead demonstrated the correct execution, and the short stops fell. His supervisor then coached him on explaining the reasoning behind the change, and the two agreed he should lead the standard work updates and the retraining that went with them. He went from fixing a problem to owning a process.
Both chains formed because both levels were practicing at once. Train only one, and neither fix happens.
How much the behavior moved
After 10 weeks, participants and managers repeated the identical assessment. More than 95% of participants, and more than 95% of their managers, said the targeted behaviors had improved. The biggest gains landed where the starting point had been weakest:
• FMDS boards with clear owners and realistic dates: +83%
• Defect responses documented against standard work: +33%
• Ownership during 5S walks without waiting for direction: +31%
• Supervisors coaching team leads instead of solving for them: +30%
• Team leads following through without reminders: +23%
The FMDS boards, rated lowest of anything at the start, improved the most. The coaching shift shows up in what supervisors wrote down: “Trained a team leader on how to not just say the line is down with a quality issue needing assistance, but to actually dig into the quality issue by checking specs of a part with QA through CMM to find root cause.”
The clearest sign that the chain was running more often is a simple count. Daily standard work conversations between team leads and operators rose from 2.45 to 3.04, a 27% increase that added up to more than 1,600 extra conversations over 10 weeks, each one another chance for an operator’s complaint to get written down.
Modeling leadership in quality conversations was the most-improved practice of all, for team leads and for supervisors, in their own ratings and in their managers’ ratings as well.
What the floor wrote down
Because every activity ended in a debriefing, the program kept a running record of what the floor was seeing. Those debriefs produced eight new standard work recommendations, including die-condition monitoring, crash-investigation retraining, and joint 5S walks. Several team leads independently flagged die quality as a drag on cycle time, and because they kept documenting it, the plant had a pattern to build a procedure on.
What made these things work would carry to any plant, whatever it produces. JTEKT assessed behavior from both sides, focused activities on specific behaviors, and it ran them simultaneously at two levels, all in less than six minutes a week. The key thing was activities to practice during the shift, which is where standard procedures usually stop being followed.
Standard work doesn’t enforce itself, and the people who enforce it are often the hardest layer in the plant to reach. JTEKT reached them inside the shift, checked from two directions whether the behavior improved, and earned a 2026 Brandon Hall Group Gold award for it.
About text formats
