Working Backward Is How You Get to Yes
The end should determine your means
愚木混株 Yumu / Unsplash
Mike Figliuolo
thoughtLEADERS
Mon, 01/26/2026 - 12:03
It’s a terrible feeling to put a ton of effort into crafting a recommendation only to have it shot down in front of all your co-workers. If you want your idea approved, you should try doing things backward instead.
Think about how you craft a recommendation. Typically, it goes something like this:
• Identify problem
• Gather data
• Do analysis
• Get an idea
• Do more analysis
• Figure out how to implement idea
• Do more analysis
• Write a big presentation that includes all the data
• Share the idea
• Get shot down
• Drink
• Repeat
It doesn’t work, folks. It just doesn’t work. Notice that nowhere in there are true stakeholder needs identified. No confirmation of the issue itself. No understanding of what the narrative should be and what stakeholders or decision makers will find exciting. Notice also how much analysis is conducted—80% of which will never see the light of day. Does this sound familiar?
Submitted by Dr. Victor E. Sower (not verified) on Mon, 01/26/2026 - 09:16
Getting Ideas Accepted
Good advice, Mike.  Showing how your idea will lead to the achievement of the organization's goals is important to gaining acceptance--particularly when you are not in a position of power.  Also using the vocabulary of the decision makers when crafting your presentation can help.
