A number that lies
MissyH/Flickr
Timothy Malone
Tue, 10/20/2026 - 12:03
Most shops accept a gauge the same way. They run a gauge repeatability and reproducibility (gauge R&R) study with 10 parts, three appraisers, and three trials. Get a %GRR under 30. File the report and move on. The AIAG criteria are familiar: Under 10% is generally acceptable, 10%–30% may be acceptable, depending on the application, and over 30% is not.
The trouble is what %GRR compares. It divides measurement variation by total variation, and total variation depends on the parts you picked. Choose parts that are spread far apart, and almost any gauge looks good. The number can pass while the gauge is unable to do the job it was bought for.
Here is a worked example, then what to look at alongside %GRR, and how to document the decision so it holds up in an audit.
The study that passes
A shaft diameter is specified at 10.00 mm ± 0.05 mm, so the tolerance is 0.10 mm wide. The gauge is a digital caliper that reads to 0.01 mm. For the study, someone pulls 10 parts from the line and the reject bin so the set covers the full range. The parts run from about 9.94 to 10.06 mm.
Submitted by RCosta (not verified) on Tue, 10/20/2026 - 12:06
specification vs Tolerance
Congratulations for your work. However, I wonder if specification range is the same of Tolerance!
Submitted by M. Hettwer (not verified) on Tue, 10/20/2026 - 18:45
When a GRR is insufficient for continuous improvement.
One of mentors once reminded me that when using a measurement system (gage) for confirming continuous improvement actions (for a given significant characteristic); that one should substitute the calculated SPC chart control limits for the specification limits to determine when that gage is suitable to detect small changes or improvements to the process.
We should remember that some OEMs also require MSA studies include Bias, Stability and Linearity.
Further, some of my German customers did rejected our GRR studies in favor of an ANOVA MSA (VDA) study. Check your customer CSR rules before submitting your PPAP.
Submitted by Ted Constantine (not verified) on Wed, 10/21/2026 - 09:36
Great Article on MSA
Timothy,
Very well done.  You articulated very well what I also teach about conducting and analyzing an MSA, include Gage R&R results.   Checking resolution and accuracy prior to conducting a Gage R&R is important.
