The Quality Observations You Aren’t Capturing
The most expensive quality data are those that never make it into the QMS
DC Studio/Adobe
Luca Ziveri
SaidText
Wed, 07/01/2026 - 12:03
A line operator in a chemical packaging plant notices a torque inconsistency on a capping head. The deviation is within tolerance on the individual reading, but the operator has seen this pattern before; it usually precedes a run of out-of-spec caps over the next two shifts. He would normally flag it. Today, he’s wearing nitrile gloves, the deviation entry form is in English, and his shift ends in 40 minutes. The observation never reaches the QMS.
Two weeks later, a customer complaint triggers a CAPA investigation. The audit trail shows nothing unusual on the day the operator noticed the pattern. The root cause review concludes the failure wasn’t predictable from existing data.
It was. The operator had seen it. The signal had simply never been given a way into the system that fit how he actually works.
This isn’t a discipline problem. It’s a structural blind spot in how quality data get captured, and it shows up in audit trails, SPC inputs, and CAPA effectiveness reviews in three patterns that quality managers can verify in their own facilities this week.
Submitted by dangermoney on Wed, 07/01/2026 - 14:09
"Correctly"
"The operator is doing the job correctly."
That's an interesting way to describe an employee who doesn't, won't, or can't communicate with his colleagues. Let's not talk about the elephant in the room: that the reason your shop floor has become the Tower of Babel in the first place is that the business seeks to undercut domestic wages with foreign labour... a rotten thing to do to people.
Submitted by Amiror (not verified) on Wed, 07/01/2026 - 23:08
Thank you
Hi Luca
Thank you for raising these important points. End-of-shift mistakes are a frequent contributor to human-error events, and the suggested practices are excellent preventive measures. Identifying unwritten norms and informal work practices is also a critical objective for quality teams, as it helps reveal hidden risks and better align procedures with actual shop-floor behavior.
Submitted by Craig Cochran on Fri, 07/03/2026 - 10:59
Culture problem
Dear Mr. Ziveri,
I would take issue with your assertion that the issues cited are not cultural. They are absolutely cultural. If a company hires 40–60% of line operators who speak English as a second or third language, that is indeed a cultural problem, one that squarely sits in the lap of top management. Companies that have problems of this sort deserve whatever QMS nonconformities that result from leadership’s shortsighted and dangerous decisions.
Sincerely,
Craig Cochran
