AI Is Already Inside Your QMS. The Controls Haven’t Caught Up.
Can organizations demonstrate who owned the reasoning behind the decisions AI helped shape?
Kundra/Adobe
Takeisha Wright
Wed, 06/17/2026 - 12:03
A CAPA investigator opens an AI-enabled quality management system and asks for potential root causes. The system produces several plausible explanations, summarizes similar historical events, and recommends corrective actions. The investigator reviews the suggestions, selects one, and closes the record.
Months later, an auditor asks a simple question: “How did you determine this was the root cause?” The record contains the conclusion. It doesn’t contain the reasoning.
The emerging quality problem
AI is now embedded throughout commercial QMS platforms. It drafts procedures. It summarizes investigations. It identifies complaint trends. It proposes risk scores. It suggests design inputs.
Organizations are adopting these capabilities because they improve efficiency. That’s a legitimate reason. The challenge is that most quality systems were built around human-generated analysis and human-owned conclusions. The controls that govern records, approvals, and traceability were designed for a workflow where a qualified individual performed the analysis and documented the basis for their determination.
Submitted by dangermoney on Wed, 06/17/2026 - 08:33
More efficient at what?
"Organizations are adopting these capabilities because they improve efficiency. That’s a legitimate reason."
I'm getting tired of everyone talking past the sale with AI. It's already here, you're already using it, and it's already making tremendous savings, so get behind it ... never mind that you're doing something fundamentally different than you are supposed to be doing; you're doing it so efficiently!
CAPA and Root Cause Analyses are very often just box-checking exercises that organisations engage in to generate documentation that shows that they care, to limit liability. So yeah... I'll bet that AI helps people generate this documentation more efficiently and move on with their lives without having to bang their heads against a problem for weeks.
Process improvement using Statistical Process Control (SPC) is the proper way to catch, probe, and ultimately mitigate root causes. CAPA only happens after some cause has worked its way through the system enough to cause problems that get detected on the back end. Very often, by the time the investigation happens, the cause has already come and gone, and you didn't catch it on your process behaviour chart when it happened, because you aren't doing process improvement using SPC.  So now you're just making your best guesses and collecting whatever evidence still might remain.
This doesn't mean that CAPA and Root Cause Analyses are useless, but they aren't the sharp edge that is going to slice through your problems. As an organisation moves towards continuous improvement via SPC, the findings of CAPA investigations can be informative for improvement efforts, and especially for helping process engineers design effective monitoring schemes to actually catch root causes when they show up. In spite of lacking key evidence for really closing the loop on a problem, the CAPA investigation will still represent the best efforts of process-knowledgeable people trying explain process behaviour... that is, until you let Grok show these desperate quality engineers a shortcut out of Hell. Then it really is just a box-checking exercise.
Submitted by Takeisha W (not verified) on Mon, 06/22/2026 - 08:51
In reply to More efficient at what? by dangermoney
AI influence on regulated decisions
I don't disagree that organizations often get more value from proactive process monitoring and SPC than from retrospective CAPA investigations. In mature quality systems, the goal should be to identify process shifts before they become nonconformances.
However, that is a different question from the one I was trying to address in the article.
Whether the activity is a CAPA investigation, risk assessment, change evaluation, document review, or process monitoring exercise, organizations are increasingly using AI to summarize information, identify patterns, suggest causes, prioritize risks, and recommend actions. The governance challenge is not whether AI should be used. It already is.
The question is what happens when AI begins influencing conclusions in regulated processes.
I actually agree with your concern that AI could turn CAPA into an even greater box-checking exercise if teams simply accept AI-generated root causes without critical evaluation. That is precisely why documentation of human review, rationale, and decision accountability becomes more important, not less.
The article is not arguing against AI adoption. It's arguing that efficiency gains do not eliminate the need to understand and document how conclusions were reached. If an investigator, auditor, or regulator asks why a particular root cause, risk rating, or corrective action was selected, the organization still needs to be able to reconstruct that reasoning.
