Don’t Create Standards Just to Create Standards, Part 2
The logistics of standardizing a specific process
Davis Balestracci
Mon, 08/22/2011 - 14:48
Any improvement effort ultimately faces the issue of standardizing processes, in many cases under the intense pressure of an impending certification audit. Ask yourself: Is your rationale for standardization merely to pass the audit, or is it a serious effort to improve quality? If it’s the former, I’m positive most of you are clever enough to put up a good front in that tiring cat-and-mouse game, and you probably thought part one of this article was too much work. If it’s the latter, then I’d like to suggest a few additional nuggets of wisdom as you work through the plan-do-check-act (PDCA) cycle as it applies to standardizing processes.
Submitted by cgneal on Thu, 08/25/2011 - 09:23
A very timely article
Thanks for the article, Davis. We have recently discovered that our documented Engineering Change process isn't being followed whole-heartedly. Part of it is by choice and part of it is because of organizational changes. A good read for me before wading into revising our standard operating procedure to make it easy to follow and add value.
