Product News: Thermocouple Calibration Instrument
Easy-to-use unit works with eight different thermocouple types.
E Instruments
Mon, 08/17/2009 - 17:45
(E Instruments: Langhorne, PA) -- The SignalCal 2 T/C from E Instruments simulates voltage and thermocouple readings for calibration purposes. The device is rugged and easy to use, measures eight types of thermocouples (R, S, B, E, K, J, T, and N), and has an accuracy of ±0.05 percent. The SignalCal 2 T/C includes:
  • The ability to select a Temperature Output Range in °C and °F
  • A new 9 V battery with an estimated battery life of 25 hours
  • A dc voltage output range of 100 mV or 1 V
  • A measuring function that allows for an input range of -10 to 110 mV
  • An easy-to-use operator panel with an easy-to-read LCD display
  • An automatic power-off feature, which turns off the unit in 10 minutes if not used
  • A low-battery display symbol, so you know when to change the battery
  • NIST traceable calibration certificate included with every unit
For more information, visit www.e-inst.com
