SCANOLOGY Introduces SIMSCAN-S Gen2
Palm-sized 3D scanner delivers 0.015 mm accuracy for high-precision inspection
Mon, 04/06/2026 - 12:03
(SCANOLOGY: Hangzhou, China) -- SCANOLOGY, a leading 3D scanning solution provider, has announced the launch of SIMSCAN-S Gen2, a palm-sized 3D scanner designed to help manufacturers perform high-precision inspections with greater confidence, speed, and flexibility.
Manufacturers are required to verify micron-level accuracy while reducing inspection time and minimizing costly rework. The SIMSCAN-S Gen2 3D scanner addresses these challenges by combining metrology-grade accuracy, advanced geometric control, and high-speed data capture in a compact and fully wireless device.
High-performance 3D inspection
The SIMSCAN-S series is designed to meet these demanding inspection requirements. With dense, metrology-grade point clouds and accuracy up to 0.015 mm, the scanner captures detailed 3D data of holes, cylinders, and critical surfaces, providing a reliable foundation for complex dimensional analysis.
• Fitting cylinders to holes to measure hole-to-hole distances
• Extracting cross sections to measure distances and radii
• Comparing scan data with CAD models to generate deviation color maps
• Conducting virtual assembly to evaluate gaps and overall fit
From experience-based to data-driven quality control
Unlike traditional inspection methods that rely on limited measurement points, SIMSCAN-S captures complete 3D surface data and compares them directly with CAD models.
The resulting color-map visualization clearly highlights even subtle deviations, allowing engineers to quickly identify potential issues in functional surfaces, machined features, and assembly-critical areas.
This shift toward data-driven inspection helps manufacturers improve traceability, reduce human error, and make faster quality decisions.
Compact, wireless, and built for real-world environments
Along with its powerful performance, the SIMSCAN-S Gen2 is highly portable, featuring a 560 g magnesium-alloy body for easy handling during extended use.
Its fully wireless design, powered by edge computing and wireless data transmission, enables flexible scanning in confined, elevated, or complex environments without cables.
An integrated display provides real-time feedback to ensure data quality and efficient workflows.
Capture more data, faster
The SIMSCAN-S Gen2 delivers high-speed scanning performance with:
• 126 blue laser lines
• Up to 8.1 million measurements per second
• Frame rates up to 180 FPS
This enables engineers to capture large volumes of detailed 3D data quickly, even when scanning complex or intricate geometries.
As smart manufacturing continues to evolve, high-quality 3D data will play an increasingly important role in predictive maintenance, process optimization, and closed-loop quality control.
About text formats
