On Viability as Truth
Multiple paths can work, but the lock still has to open
Priscilla Du Preez 🇨🇦/Unsplash
Harish Jose
Harish’s Notebook
Wed, 04/01/2026 - 12:01
I am exploring what I think is a fundamental question in epistemology: What does it mean to say something is true? I want to approach this through the lens of cybernetic constructivism. I’ll start with a question about pi, which feels fitting given that I wrote this on March 14.
What is pi? For most purposes, 3.14 is a very accurate value. But pi is an irrational number. It goes on forever. Should a truthist spend a lifetime reciting its digits? Where should they stop and say: This is pi.
That question is the crux of viability. A correspondence theory of truth has no stopping rule. It’s committed, in principle, to the full expansion. But nobody does that, because it doesn’t prove viable for any actual purpose. For most engineering calculations, 3.14 works. More decimal places work for orbital mechanics. The stopping point is always set by the task at hand, not by some ideal of complete accuracy.
A correspondence theorist might reply that they can simply know pi is infinite without reciting it. But that reply concedes the point. To know that pi is infinite is to already accept a stopping rule. The question is what determines where you stop. Viability puts the stopping rule at the heart of truth. Correspondence theory treats it as a practical afterthought.
What I find striking is what the history of pi actually shows. The Babylonian engineer used 3. The medieval architect used 22/7. NASA uses 15 decimal places. The mathematician holds the concept of an infinite irrational ratio.
Mathematically, there is a unique value of pi. The description that has proved most robust across the widest range of tests is the one that survives. That is viability selecting the winner. Classical correspondence theory has little to say about why our descriptions of pi changed over time or differ among contexts. It treats these shifts as practical side-effects rather than as central to what truth is.
Coping, not copying
Once you notice that every stopping rule is task-relative, you’re already moving toward a cybernetic picture: knowledge as regulation under constraint rather than as static mirroring.
Let’s look at the example of a lock. A lock can be opened with a key, a lock pick, or a hammer. All three work. None of them is the one true solution. The opening of the lock is the criterion, not the method. This is what viability means in practice. It doesn’t collapse into the view that anything goes. The lock still has to open. But multiple paths can satisfy the criterion. This is the notion of pluralism.
Correspondence theory assumes that an accurate copy of the world can be made in the mind. But this assumes we have direct access to the world in the first place. Cybernetic constructivism starts from the opposite standpoint. We don’t have direct access. What we have is a context, an observer embedded in a situation, acting under constraints. The cybernetician is aware of the trap of relativism that follows if epistemic constructivism is taken too far. The answer therefore is not to abandon external reality but to let it push back. External constraints aren’t obstacles to truth. They’re its guide.
What emerges from this isn’t a copy of the world but a structural coupling with it. The focus shifts from copying the world to coping with it. It’s worth pausing on the word truth itself. In Old English, trēowþ meant faithfulness and keeping one’s word. The narrowing toward factual correctness came much later. Its deepest root means firm and solid, from the same family as tree and trust. This suggests not a mirror of reality but something that holds fast under strain. Even in its language history, truth is less about a disembodied view from nowhere than about reliability in a lived relationship.
Viability, as the cybernetician uses the term, isn’t a lazy shortcut to truth. It’s a different account of what truth is for. Knowledge is not a mirror held up to reality. It’s closer to a tool. A tool fits or it doesn’t fit, relative to what you’re doing. Pi is not first true and then useful. Its usefulness is the ground of its truth claim.
As I was thinking about this, I couldn’t help but notice how well this connects to a tradition that predates cybernetics. American pragmatists, John Dewey and William James in particular, argued that the truth of a belief is inseparable from its consequences in practice. Dewey called knowledge a form of inquiry, not a form of contemplation. James spoke of the cash value of a truth, meaning the practical difference it makes to the person holding it. Cybernetics inherits this instinct and gives it a more precise mechanical account, grounding it in feedback, constraint, and structural coupling rather than in human psychology alone.
Readiness to hand
This is also what Martin Heidegger points to with the notion of readiness to hand. A hammer is not first an object you contemplate and then use. It’s defined by its role in a practice. You notice the hammer as an object only when it breaks or goes missing. Otherwise, it’s simply part of how you are engaged with the world. In the same way, a number like 3.14 isn’t something you verify against reality and then apply. It’s already inside the practice. Its truth is its grip on what you’re doing.
This brings in a second aspect of viability. It’s always relative to what we have on our hands. The constraints of the task determine what counts as sufficient. A cybernetic observer is always embedded in a context of action. What counts as a sufficient description depends on what the observer needs to do next. This is why cybernetics reaches for viability rather than correspondence.
Viability, in more precise terms, is about maintaining the ability to act when facing constraints. It’s not about removing constraints. It’s about sustaining the capacity to continue within them.
King Sisyphus
The myth of Sisyphus makes this idea vivid. In Camus’ retelling, Sisyphus is condemned to roll a boulder up a hill, only to watch it roll back down, again and again, for eternity. The constraint doesn’t change. The boulder always returns. But Camus insists we imagine Sisyphus happy. And this isn’t a small thing.
The punishment depends on Sisyphus experiencing it as a punishment. The gods aren’t just constraining him physically. They’re constraining him through his own suffering. If Sisyphus finds joy in what he does, the punishment loses its force because it ceases to be punishment at all. The rock still rolls back. But the meaning of that event changes entirely.
There are two constraints at work here, not one. The physical constraint belongs to the hill and the boulder. The second constraint belongs to the relationship between Sisyphus and his situation. This, to me, is what W. Ross Ashby points to when he treats constraint as a relation between an observer’s possible descriptions and what actually happens. The gods were counting on both. They chose this task because they expected Sisyphus to find it intolerable.
When he finds joy instead, the second constraint dissolves. The punishment ceases, not because the rock stops rolling but because the meaning of the rolling changes. Sisyphus is no longer measuring his situation against an impossible standard, namely the boulder staying at the top. The rolling back is no longer a failure. It’s just the next push.
This is also where the line between reframing and delusion holds. Sisyphus dissolves the relational constraint, the one the gods constructed, while remaining fully exposed to the physical one. The rock still rolls back.
Delusion works differently. It doesn’t reframe what you measure yourself against. It avoids the test altogether. Reframing and avoidance look similar from the inside, but they’re not the same thing.
There’s something else here worth noting. The gods defined the task as punishment. Sisyphus, by finding joy, becomes his own observer. He steps outside the frame the gods imposed. In second-order cybernetics terms, he observes his own observing and chooses differently. Viability, in this reading, isn’t just functional persistence. It’s the capacity to reframe one’s relationship to a constraint.
The Madman of Naranam
I want to bring in a figure I find even more striking than Sisyphus for this purpose. Consider Naranath Bhranthan, the Madman of Naranam from the Indian state of Kerala. He too rolled a large rock up a hill and watched it roll back down. He did this again and again. But he wasn’t being punished. Instead, he did it for fun. The stories say he would laugh with joy and clap his hands as the rock rolled down.
Naranath isn’t denying the physical constraint. The rock rolls back, and he knows it will. His reframing doesn’t change what happens. It changes what he measures himself against. He stops applying a standard that was never appropriate to begin with. He needed no outside observer to imagine him happy. His reframing was self-generated.
The story of Naranath meeting the goddess Kali makes this even more vivid. Kali offered him any boon he wished. He asked only to move his elephantiasis from one leg to the other. He didn’t ask to be free of it. He had understood the absurdity of demanding that the world be other than it is. That understanding is viability in its deepest form.
Camus’ formulation still requires an observer. We must imagine Sisyphus happy. Naranath doesn’t wait to be imagined. This is, perhaps, the deeper cybernetic point. Viability looks like a property of the organism. But the Sisyphus example reveals it as partly a property of the relationship between the organism and its observer. Naranath collapses that distance. He’s the observer of his own condition, and he chooses joy without being told to.
The community problem
If viability is partly about how an individual organism relates to its constraints, the question arises about how communities do this collectively. Charles Sanders Peirce proposed that truth is what a community of inquirers would converge on, given enough time.
But this raises a prior question. Who gets to be in the community? A group that agrees the earth is flat is also a community. Peirce’s community of inquirers works only if the community remains open to the tests imposed by its environment. Without that, coherence collapses into shared delusion. The flat earth holds together perfectly well as a coherent position until you try to launch a satellite. At that point the context decides, not the community.
This is also where viability parts ways with a purely psychological reading of coping. A belief that works by insulating itself from defeat isn’t viable in the cybernetic sense. It’s a closed loop. Popper called this falsifiability: A claim should be viewed as knowledge only if it is open to some possible observation that could defeat it.
Viability makes the same demand from a different angle. A viable belief is one that remains genuinely exposed to the push-back of its constraints. Structural coupling requires contact. A placebo, for example, can open the lock once or twice. But a belief that can’t be tested by the lock at all isn’t knowledge. It’s insulation.
Coherence and its limits
When you encounter something genuinely new, you can’t easily make sense of it. This is because you don’t yet have a network of understanding into which it can fit. The new observation has no hook to hang on. A claim doesn’t arrive in isolation. It either coheres with the network of details you already hold, or it doesn’t land at all. Reading widely and across diverse domains is one way to build a network rich enough to receive new things.
From this standpoint, truth has two criteria working together. First, it must cohere with what you already understand. Second, it must sustain your viability rather than erode it. The two aren’t equal. Coherence is necessary: A completely incoherent set of beliefs can’t support action at all. But coherence isn’t sufficient. A perfectly coherent but closed network will eventually fail you. Viability is the deeper criterion. Coherence is subordinate to it.
Correspondence theory assumes that truth is already out there, waiting to be found. Viability inverts this. Truth isn’t found. It’s enacted in the relationship between an observer and their constraints. The question isn’t whether something matches reality. The question is whether it allows you to continue.
Frames and open questions
Consider a rocket launch. The rocket either reaches orbit or it doesn’t. That criterion is external and unambiguous.
Political and social evaluations are harder because the criteria are themselves contested. Two groups disagreeing about a leader aren’t just disagreeing about a fact. They’re disagreeing about what counts as a good outcome. That’s a disagreement about values, not just evidence. It’s a disagreement about which outcomes count as success.
I’ve written about Heinz von Foerster’s ethical imperative before in the context of Russell Ackoff. Von Foerster offers one possible criterion that sits outside tribal agreement. His ethical imperative is to act always so as to increase the number of choices available. Choices here mean systemic variety and the capacity to respond to constraints not yet encountered, not merely an expanded menu of options. That’s at least a criterion that doesn’t depend on who’s in the tribe. But even that criterion must be chosen by someone. The honest cybernetic answer to who decides the context is: The observer does, always. But the observer decides the frame. The universe decides whether the frame survives. These are not the same thing.
Even if truth is a property of propositions, any ascription of truth is made from within a perspective. Every act of saying this is true is an act by some observer under constraints. There is no view from nowhere.
Existentialism arrived at this conclusion from a different direction. Søren Kierkegaard argued that the deepest truths tell the individual what to do, not what to know. Friedrich Nietzsche went further, famously claiming that there are no facts, only interpretations, and that we can’t see around our own corner. Pragmatism made a parallel move, arguing that truth isn‘t a fixed target but a process, something that happens to an idea as it’s put to work.
Cybernetic constructivism inherits both traditions and gives them a more precise account of what the corner is made of and what putting an idea to work actually means. What we can ask is whether a perspective is richer, more generative, and more honest about its own assumptions than another. Viability isn’t a compromise on truth. It’s a more honest account of what truth has always been doing.
One question remains open. This article has argued that the universe decides whether the frame survives. But what happens when a community is so digitally insulated that it never has to launch a rocket? When algorithmic walls are thick enough that the physical pushback never arrives? A flat earther, for example, doesn’t need to test their belief if they never have to launch a satellite. This is perhaps the sharpest challenge viability faces in the present moment.
The answer the cybernetic constructivist would give is that insulation is itself a constraint. A community that never tests its beliefs against the world isn’t viable in any durable sense. It’s merely coherent. And coherence, as this article has argued, is the subordinate criterion.
The full arc
This article began with a simple question. Where should a truthist stop and say this is pi? That question opened into something larger. Truth, from a cybernetic constructivist standpoint, isn’t a mirror held up to reality. It’s a relationship between an observer and their constraints. The stopping point is always set by what you need to do next.
The lock example showed that viability isn’t relativism. Multiple paths can work, but the lock still has to open. The Peirce detour showed that agreement isn’t the criterion either. A community can agree and still fail when the context changes. Sisyphus and Naranath showed that viability isn’t merely functional. It’s the capacity to find a relationship to your constraints that allows you to keep going. Naranath, offered any boon he wished, asked only to move his elephantiasis from one leg to the other. He had understood the absurdity of demanding that the world be other than it is.
And the coherence point showed that for something new to register as true, it must first find a hook in what you already understand, and then sustain rather than erode your ability to act. A community that never tests its beliefs against the world isn’t viable in any durable sense. The universe doesn’t argue. It simply decides which frames survive.
The universe is patient.
Notes
In referencing the work of Heidegger, I want to acknowledge the deeply troubling fact of his affiliation with the Nazi party. This aspect of his life casts a long and painful shadow over his legacy. While I draw on specific philosophical ideas that I find thought-provoking or useful, this is not an endorsement of the man or his actions. Engaging with his work requires ethical vigilance, and I remain mindful of the responsibility to not separate ideas from the broader context in which they were formed.
If you liked what you’ve read, please consider my book Second Order Cybernetics, available in hard copy and e-book formats: https://www.cyb3rsyn.com/products/soc-book.
Published March 13, 2026, in Harish’s Notebook.
About text formats
