In precision machining there’s a particularly deceptive failure mode. Everything looks fine. The toolpath is clean, cutting is stable, the part’s almost finished. And then you discover that you took off too much somewhere. Or the opposite—you left a small island of stock that now must be removed by hand. Or during the next setup, the tool suddenly can’t reach because the fixture wasn’t properly accounted for.
The cost hits the most expensive things first: time and repeatability. And when you’re running batches, there’s the added penalty of scrap—parts you simply can’t save.
At HIN Feinmechanik, this is a shop-floor reality. What makes this company’s story interesting is how it solved the problem—not by “being more careful at the machine” but by moving control upstream, into preparation, where mistakes are still cheap.
Company and production context
HIN Feinmechanik GmbH is a German manufacturing company producing high-precision milled and turned components for mechanical engineering, medical technology, and other high-tech industries. The business started in early 2014, was established as a GmbH in 2017, and in 2020 moved into a larger facility of about 650 m²—an intentional step toward growth and more demanding production work.
The day-to-day work is built around tight tolerances, stable quality, and the ability to switch quickly from one job to the next. That’s why any uncertainty in CAM preparation becomes a problem fast.
Why precision parts get ruined at the end
The issue is usually not that the CAM made a mistake. It’s that with high precision and complex geometry, small details translate directly into time and money:
• It’s hard to know in advance where and how much material is actually being removed.
• It’s easy to miss a spot where excess stock remains—leading to manual bench work.
• In setups, there’s a risk that fixturing and real part geometry aren’t reflected correctly.
• Collisions and near misses are often discovered late, during setup on the machine.
• Every late surprise triggers extra prove-outs, stops, and in the worst case, scrap.
When this happens too often, production stops running on plan and starts running on postmortems.
Switching CAM software
For many years HIN worked successfully with a previous-generation CAM system. But requirements—including programming speed, accuracy, and process control—kept rising. Eventually it became clear that the previous level of performance and functionality was no longer enough to keep pace without extra iterations and without catch-up edits at the machine.
That’s how HIN arrived at ENCY. After the switch, several things changed.
Programs started coming together faster through reuse, not rush
HIN notes that the time savings came from making many steps standardized and reusable. With templates, libraries, and automated strategies, programming doesn’t start from zero every time. Variants and modifications become easier without rebuilding the whole program. That matters in real production. Speed isn’t one fast job but the ability to keep a steady rhythm week after week.
Stock-removal control became a real tool, not a guess
One of the key effects they highlight is precise control of material removal. When you can see removal and remaining stock ahead of time, it’s easier to decide on strategy and stock allowance. Fewer issues appear late, when it’s already expensive.
“The strength of the software is fast and efficient programming, which saves us noticeable time every day,” says one user. “Especially important is precise control of material removal and the ability to reliably check for collisions.”
Simulation became an insurance policy that cuts setup time and scrap
Simulation often gets treated as a nice feature. At HIN, it functions as a risk-reduction tool. Before cutting metal, they can see the machine, spindle unit, tool, and holders in the model—and, crucially, they can quickly add different fixture variants into the simulation.
That’s a practical point. In real life, fixturing changes. If it isn’t reflected in verification, collision risk comes right back.
In simulation, the machine, spindle unit, tools, and holders are displayed realistically. This provides a high level of safety. In addition, different clamping devices can be added to the simulation quickly and easily.
“This keeps us flexible and allows us to run complex scenarios safely,” says another user.
The shop-floor result of this insurance is fewer unexpected stops, less setup effort, and more predictability, especially when launching batch production.
Quality improved where the expensive small things usually hide
Users also emphasize better part quality. More accurate toolpaths lead to a more stable process, smoother load, and a better surface finish. That hits the two most painful areas directly: manual rework and scrap.
In HIN’s experience, the quality improvement translated into production outcomes: less manual finishing work, higher repeatability, and, importantly, a noticeable reduction in scrap rate.
HIN doesn’t run a single-part family. One day it’s one material and geometry; the next day it’s different. That’s why this combination matters for the company to:
• Build programs quickly from structured blocks and templates, not from scratch
• See actual stock removal and remaining stock before cutting
• Verify collisions and operation logic
• Include real fixturing directly in simulation
• Only then commit to cutting metal
It’s not luck at the machine. It’s a predictable process.
A partner that closes questions fast
Customer service is also important. It’s not only the software that matters, but also how quickly day-to-day issues get resolved. Users highlight not only functionality, but also support—fast responses, competence, and clear communication. Answering requests quickly, competently, and in a friendly manner is critical for any company. In addition, ENCY offers a wide range of problem-solving strategies and can find a solution for almost any task.
Reducing time and risk around the machine
This story is about simple production math:
• Faster preparation because templates and strategies can be reused
• Fewer surprises because stock removal and collisions are controlled
• Less setup effort and scrap because simulation includes real fixturing and exposes risk early
• Higher repeatability because the process is more stable, and surface finish is more consistent
That’s how HIN Feinmechanik moved risk from the shop floor into preparation—where it can be seen, explained, and fixed without losses.
