Beyond the Pit: Why Laboratory Integrity Now Shapes Mining Viability
As gold and rare earth projects tighten economic thresholds, analytical precision moves to the center of decision-making
Samuel Chagas / Unsplash
Greg Rankin
Rankin PR
Wed, 04/01/2026 - 12:02
As mining operations push toward lower-grade deposits and tighter economic margins, the reliability of analytical measurement has become central to operational decision-making.
From representative sampling to traceable calibration standards and certified reference materials, the systems used to verify assay accuracy increasingly determine whether reported grades can be trusted. In modern mining environments, the integrity of these measurement foundations directly influences how deposits are modeled, resources are reported, and, ultimately, whether material is considered economically viable.
With commodity prices rising across the mining sector, from gold to strategically critical rare earth elements, more material has moved back into economic consideration. This has placed greater emphasis on reliable and defensible analytical results. When gold reached record levels earlier this year, material long considered marginal was suddenly worth another look. Stockpiles were revisited, lower-grade zones returned to the model, and economic assumptions were recalculated in light of a new price reality.
That recalibration narrows the margin for analytical uncertainty. As projects operate closer to economic thresholds, small differences in assay results begin to carry greater weight across exploration programs, grade control, and processing decisions.
This shift places new weight on the metrology behind the assays themselves. As economic boundaries tighten, calibration standards, traceability chains, and certified reference materials used to validate analytical instruments become central to operational confidence. Reliable standard reference materials are no longer a background procurement decision; they underpin whether reported grades can be trusted.
In many operations, the line between sending material to the mill or to the dump hinges on fractions of a gram per tonne. This is true in gold projects adjusting cutoff grades or in rare earth deposits managing complex elemental distributions. At that scale, analytical data do more than confirm grade; they shape classification, recovery modeling, and long-term resource estimates.
In publicly traded mining companies, mineral reserves are reported under formal disclosure frameworks such as the SEC’s Modernized Property Disclosure Requirements (Regulation S-K Subpart 1300), Canada’s NI 43-101, or the internationally recognized JORC Code. These disclosures are prepared by qualified professionals and must be supported by defensible analytical data underlying the resource model and the modifying factors applied in feasibility studies. In projects operating near cutoff, laboratory results directly influence economic classification decisions.
“The difference between a viable project and a marginal one can come down to analytical precision,” says William R. Sattlegger, CEO of i2iVestcom Advisors Corp. and executive director of the Critical Minerals Conference. “Those numbers drive metallurgy, recovery, and valuation models. If you lose confidence in the data, you lose confidence in the project.”
Consider a deposit processing 20 million tonnes annually at a cutoff near 0.5 g/t. A shift of just 0.05 g/t in reported grade, whether from sampling variability or calibration bias, can alter how large volumes of material are classified. Across that scale, even small analytical differences can translate into meaningful economic consequences.
Sampling risk: The first point of failure
Before instrumentation or calibration is evaluated, a more fundamental question must be answered: Is the sample representative?
‘In mining, it’s really the sampling. A poor sample can lead to swings of over 50% in reported values.’
—William R. Sattlegger
“In mining, it’s really the sampling,” Sattlegger says. “A poor sample can lead to swings of over 50% in reported values.”
Such variability can distort block models, misclassify material, and undermine reconciliation between predicted and actual production. Even the most advanced ICP-MS system can’t compensate for a nonrepresentative sample.
For that reason, serious operations build layered QA/QC systems around sampling integrity. Blanks monitor contamination. Duplicates assess precision. Certified reference materials (CRMs) verify accuracy. CRMs are homogeneous, well-characterized materials with known elemental concentrations, validated through traceable measurement procedures and used to confirm that analytical systems are producing accurate results. In many cases, these materials are traceable to national metrology institutes and accompanied by certificates documenting uncertainty budgets, preparation methods, and stability data.
In exploration programs, these controls support resource estimates used in prefeasibility and feasibility studies. In producing mines, they safeguard grade control and metal accounting.
As projects move closer to economic thresholds, QA/QC shifts from procedural discipline to active risk management. Investors, regulators, independent technical reviewers, auditors, and stock exchange reporting requirements increasingly demand clear evidence that sampling and verification protocols are robust, repeatable, and well documented.
Without confidence in sampling integrity, the rest of the analytical workflow loses credibility.
Calibration in complex mining matrices
Even when sampling is disciplined, analytical chemistry must withstand challenging matrices.
Gold operations frequently involve cyanide leach solutions, high total dissolved solids digests, and complex metallurgical streams that can interfere with signal stability. Rare earth deposits introduce a different challenge: chemically similar elements across the lanthanide series, often occurring at low concentrations, where small analytical biases can distort distribution modeling and downstream separation economics.
Accurate results depend not only on instrument performance but also on calibration alignment. In high-TDS systems, mismatches between sample matrices and calibration standards can introduce systematic bias. Dilution steps intended to protect instrumentation create additional exposure to contamination, signal suppression, or drift. In rare earth analysis, interference correction, method validation, and traceable calibration become central to defensible reporting.
As projects advance toward bankable feasibility studies or reserve disclosures, defensibility carries as much weight as detection limits. Technical reports must demonstrate repeatability, traceability, and calibration practices capable of withstanding scrutiny from regulators, independent engineers, investors, and securities exchanges.
At that stage, the calibration point behind the instrument is no longer a laboratory detail. It becomes part of the project’s economic foundation.
Analytical supply chains adapting to mining’s demands
These pressures are reshaping expectations throughout the analytical supply chain.
“As grades decline and deposits become more complex, the margin for analytical error narrows,” says Brian Alexander, chief technical officer of Inorganic Ventures, a manufacturer of inorganic certified reference materials produced under ISO 17034 accreditation and supported by ISO/IEC 17025-compliant analytical testing. “In mining, you’re often working at trace levels in difficult matrices. If calibration doesn’t reflect the chemistry you’re measuring, small biases can compound.”
‘As grades decline and deposits become more complex, the margin for analytical error narrows.’
—Brian Alexander
In one gold operation working near its cutoff threshold, reconciliation differences emerged between process samples and laboratory assays. Instrumentation performed as expected. The issue traced back to calibration alignment within a cyanide matrix. After shifting to matrix-matched standards and strengthening documentation protocols, variability decreased and confidence in reported values improved.
The trend extends beyond centralized laboratories. More analytical work is moving closer to the mine site, where faster decision cycles and leaner staffing increase reliance on stable, predictable calibration behavior.
“When testing moves closer to operations, you’re making decisions in near real time,” Alexander says. “That increases the importance of well-characterized standards, documented uncertainty, and clear traceability.”
In this environment, suppliers that understand matrix effects, documentation rigor, and method alignment increasingly influence analytical reliability, even if their role remains largely behind the scenes. Companies such as Inorganic Ventures have responded by developing matrix-matched CRMs, extended shelf-life formulations, and technical support models designed for high-throughput mining environments.
Rare earths, gold prices, and the shrinking margin for uncertainty
Rare earth development, accelerated by strategic mineral policy and supply chain realignment, introduces additional analytical complexity. Multiple elements at low concentrations require careful interference control and stable calibration across analytes. Even a small bias can distort modeled distribution and downstream separation economics.
Gold operations face parallel pressure. With sustained high prices, marginal zones and stockpiles move back into economic consideration. When cutoff grades shift by fractions of a gram per tonne, assay precision influences how large volumes of material are classified and valued. In both cases, the implications extend well beyond daily production metrics. Resource estimates, environmental disclosures, technical reports, and financing models depend on defensible analytical foundations.
“What’s changed isn’t that QA/QC exists. It always has,” Alexander says. “What’s changed is how closely projects operate to their economic limits. As margins narrow or mineralogy becomes more complex, the tolerance for uncertainty shrinks. Data that might once have been acceptable under older operating conditions is no longer sufficient under today’s reporting standards and investor expectations.”
For geoscientists, metallurgists, and laboratory managers, analytical testing is no longer a background function. It’s a control point within the economic model itself.
Heavy equipment may move the rock. But in modern mining, it’s the integrity of the assay, along with the systems that support it, that ultimately determines whether that rock creates value.
About text formats
