The 4 metrics you need to track
Jakub Żerdzicki / Unsplash
Bryan Christiansen
Limble CMMS
Thu, 01/29/2026 - 12:02
You finished the plan, you executed the work, and you know your team delivered results. But when it’s time to prove your budget request or show value to leadership, you struggle to give clear proof.
Maintenance teams can have a tough time transitioning from “doing work” to “reporting value.” The language used on the floor (hours logged, parts fixed) doesn’t translate to the language of the executive team (cost savings, uptime). If you only report how busy your team was, maintenance will always look like a cost center.
To secure long-term funding and support, you need to regularly report a few key performance indicators (KPIs) that tie maintenance activities to financial outcomes. These metrics create a link between your daily tasks and the bottom line.
Let’s break down the four most important KPIs you should track and report regularly to prove your plan’s success, justify your budget, and get that future funding.
Why regular maintenance KPI reporting matters
If you only report once a year, you’re making a big mistake. Regular reporting is not just an administrative task; it’s a management tool that supports accountability, drives action, and builds trust.
Here’s why tracking your KPIs on a monthly or quarterly basis is nonnegotiable for a successful plan.
Drives accountability: Regular reporting keeps your team accountable to measurable, time-bound goals throughout the year, keeping the plan top-of-mind.
Early warnings: By reviewing metrics monthly, your report can act as an early warning system. If you notice an important KPI dipping in June, you can address the issue in July. Waiting until December to notice a missed goal stops you from being able to take preventative action.
Organizational trust: Consistent, transparent reporting about your progress and challenges builds trust with other teams, such as operations and finance.
The four maintenance KPIs that prove value
When you start presenting your maintenance results to leadership, it’s important to keep things simple and relevant. Executives don’t want a long list of maintenance metrics; they want to see a clear story of financial improvement and risk reduction.
Your maintenance plan will be judged on a few metrics that help paint that picture. These four KPIs connect your team’s day-to-day work directly to the bottom line.
1. Why executives care about uptime percentage
Uptime measures asset availability. It shows the percentage of time your assets are running and delivering value. This is especially important for operations and revenue. Every percentage-point increase in uptime is a direct boost to production capacity. By completing preventive tasks, you are literally showing that maintenance is increasing the company’s ability to make money. You can use this metric to show a steady, data-driven increase in production capacity linked to your strategy.
2. What planned maintenance percentage says about control
This KPI is the ratio of planned work vs. reactive or emergency work. The goal differs by industry, but you always want to aim for a high percentage of planned work, around 80% or more. This metric proves your plan is working strategically. Reactive work is always problematic, expensive, and rushed. An increase in planned maintenance percentage leads to less reactive work and shows a shift from firefighting to control.
3. How spare-parts spending affects maintenance budget justification
This metric tracks actual inventory costs compared to the annual budget, focusing on unscheduled and rushed emergency parts spending. Inventory is a major maintenance cost. Spending less on expensive emergency parts is a big financial win. This KPI shows fiscal responsibility and the effectiveness of standardization. Use it to prove that your maintenance plan is cutting unnecessary spending, reducing high-cost rush orders, and improving overall inventory accuracy.
4. What average PM completion time reveals about labor efficiency
Preventive maintenance (PM) completion time measures the average time it takes to complete a preventive maintenance task. This KPI shows how well your process improvements and standardization are working. If PM times decrease and become more consistent for technicians, it means your training is working and labor is more efficient. This metric shows you’re boosting your labor ROI and completing more work in less time.
How to automate maintenance KPI tracking and reporting
You’ve defined the four most important KPIs. Now you need to track and report them consistently without overwhelming your team.
The usual approach to putting together these reports manually from paper forms or spreadsheets is a pretty big waste of time that leaves a lot of room for error. The time you spend chasing down data is time you’re not spending actually executing the plan.
This is where a strong computerized maintenance management system (CMMS) becomes so important.
A CMMS (like Limble) automates the entire reporting process. Because all your work orders, inventory transactions, and asset data are logged in one system, the CMMS instantly calculates and organizes all four of the KPIs we discussed: uptime, planned maintenance, parts spending, and completion time.
A CMMS turns data collection from a time-consuming administrative task into an automation that makes monthly reporting accurate and easy. Instead of spending days putting together spreadsheets, you can spend minutes creating a dashboard that tells a clear story of your department’s value.
How to report maintenance results as business value, not activity
The difference between a cost center and an investment center is how you report your results. Proving your maintenance plan’s success comes down to tracking a small set of high-impact KPIs. Together, uptime, planned maintenance percentage, spare parts spend, and average PM completion time tell a clear story of financial improvement and risk reduction, giving leadership the data they need to see your value.
Remember, if you want your budget to be seen as an investment, you have to report results, not just requests.
To build a maintenance plan that automatically tracks these results and proves your ROI, download Limble’s Annual Maintenance Plan Guide for a complete blueprint.
Published Jan. 5, 2026, by Limble.
Related Articles
Don’t Shake Before You Listen
Throwing the Fish Back Into the Water
About text formats
