When Performance Flatlines
How to stabilize, protect value, and restore momentum
Michel E / Unsplash
Maartje van Krieken
Chaos Games Consulting
Mon, 01/05/2026 - 12:02
Performance rarely collapses with fanfare. More often, it flatlines quietly; sales soften, productivity slows, priorities blur, and yet teams run hard without moving the needle. In 2025, the RSM U.S. Middle Market Business Index slid from the low 140s into the low 120s in a short period, with fewer than four in 10 firms reporting revenue gains, and fewer than half seeing higher earnings. In other words: The midmarket is squarely in the “flatline” zone, where value leakage becomes a real threat.
Leaders often sense the pulse weakening—more effort with less return—yet underestimate how quickly value drains during this phase. And once value slips faster than it’s created, recovery in a volatile market becomes an uphill climb.
A flatline rarely signals a lack of strategy or intelligence. More often, it means the system is overloaded, misaligned, or operating beyond true capacity. Pushing harder only accelerates decline.
Stabilization, not inspiration or transformation, is the most valuable move when performance stops responding. It’s emergency room principles: Stop the bleed, restore rhythm, then move into recovery.
Stabilization is a cyclical discipline built around five practical elements:
• Prioritization
• People
• Practicality
• Fit for purpose
• Predictability
Done well, these five P’s stop value loss quickly and rebuild the momentum leaders urgently need.
1. Prioritization: Stop the overload before it spreads
Most flatlines begin with well-intended overload: too many goals, too many initiatives, too much noise. Prioritization is the first stabilizer, and it’s not a list but a diagnosis. Start with three questions that anchor value:
• What directly drives value in our business?
• Why now, and all of it or only some?
• Says who, and why does it matter?
This shifts prioritization from opinion to purpose. The answers reveal what must be paused, stopped, or deprioritized, and what simply needs doing (assign and let go) vs. what requires intelligence, coordination, or multidisciplinary involvement. This is where leadership bandwidth must go.
Your outcome is a short, communicable definition of “What we work now and why.”
2. People reactivation and empowerment
In a flatline, leaders often ask, “Who should do this?” The better question is, “Who realistically can do this?”
People have different levels of capacity:
• Who has energy left?
• Who carries an invisible load?
• Who connects to critical stakeholders?
• Who holds key insight, field knowledge, or client signals?
People don’t just hold tasks. They hold intelligence and energy, and they can be tuned in or tuned out. Stabilization requires bringing as many relevant people into the process as is practically possible.
Empowerment then becomes straightforward:
• Who understands the priorities and the reasons for them?
• Who can take charge of which piece?
• What guardrails and check-in rhythm are needed?
Distribute authority only after clarity exists. Empowerment without prioritization is chaos; empowerment after prioritization is acceleration.
3. Practicality: Make it work with what you have, not what you wish you had
Flatlined companies talk themselves into paralysis by waiting for “the moment.” But you don’t have time for the next hire, cycle, meeting, or data drop. Stabilization is never about later. It’s about right now.
Practicality means using:
• The capacity freed through prioritization
• Leaders who can step up today
• Capabilities you already have
• Partnerships you can temporarily extend
• Fractional expertise that can plug gaps fast
This is another ER principle: Treat with the resources available now. Ask:
• Who has done this before?
• Who has 60% capability and can be supported?
• How can I fill critical expertise gaps quickly?
• Which external partner can give a temporary lift?
Practicality isn’t cutting corners; it’s restoring oxygen to a system that can’t wait.
4. Fit for purpose: 80/20 wins the recovery
Once the team starts moving, leaders must apply fit-for-purpose principles. Many companies stall by perfecting proposals and processes that only need to function well enough to move forward.
Fit for purpose means:
• 80/20 thinking: Fine-tuning is a nice-to-have
• Progressive insight: Take a step to learn more
• Order-of-magnitude clarity: Do you have enough understanding to move sensibly?
• Risk proportionality: Keep it as low as reasonably practical
In an ER, you don’t run a full diagnostic panel before stopping a bleed. In business, you don’t need maximum data from everywhere, especially the same message amplified by algorithms into false confidence.
Use the problem-solving methods your people know, rely on relevant data from trustworthy sources, and bring in an external perspective to expose bias and blind spots.
Stabilization is about good enough to move safely, not comfortably or with perfection.
5. Predictability: Build a rhythm that protects value
Predictability is about where we have control and where we want control:
• Where you need predictable outcomes to protect value
• Where you have predictable inputs
• Where you don’t have predictability (and never will)
Leaders fail by expecting predictability where it can’t exist. Stabilization means identifying where reliability is possible and building margin, monitoring, and escalation for the rest.
Predictability isn’t controlling volatility. It’s knowing where consistency matters and creating the rhythm that keeps you there. Short feedback loops, clear communication, and stable execution with adequate controls turn stabilization into recovery, and recovery into value creation.
Stabilization: The bridge to value recovery
When performance flatlines, “thinking on it” or launching big change only deepens the strain. Stabilization stops the value bleed, restores capacity, and brings the business back to a sustainable rhythm. That’s what the business ER delivers: fast, practical, purpose-fit interventions that protect value and restart momentum. The companies that stabilize quickly recover faster and close their gap to potential far more effectively than those that wait.
About text formats
