CADEXSOFT Announces MTK Workbench Release
Desktop application for viewing, testing, and deeply analyzing MTK workflows
Tue, 12/09/2025 - 12:02
(CADEXSOFT: Tallinn, Estonia) -- CADEXSOFT has announced the release of Manufacturing Toolkit 2025.7: a CAD SDK for developers building quoting, DFM, and MaaS platforms.
MTK Workbench initial release
MTK 2025.7 introduces MTK Workbench—a desktop application for viewing, testing, and deeply analyzing MTK workflows before full integration into custom applications. It supports import and export of all MTK-compatible file formats, with an integrated 3D/2D viewer offering navigation tools, a model tree, and property inspection.
Core MTK capabilities, such as Feature Recognition, DFM Analysis, Unfolding, and other workflows are available directly within Workbench. Users can switch between wireframe and shaded visualization modes, and choose from multiple selection types, including solid, face, wire, edge, and vertex, for precise interaction with models.
PDF import for 2D curves
The new MTK release expands support for working with 2D drawings. While the previous version introduced the ability to export 2D curves to DXF, now users can also import 2D curve geometry from PDF.
MTK converter updates
New API Utilities::JSONSerializer
MTK Converter has been enhanced with a Utilities::JSONSerializer API that simplifies the generation of JSON reports for features and DFM issues, ensuring consistent performance across C++, C#, Java, and Python.
Multibody support has been added, updating the JSON structure to include processing results for all bodies in complex parts.
New DFM checks
Narrow cutout issue (sheet metal)
New sheet metal DFM checks now include cutouts that are too narrow for proper cutting, helping to avoid incomplete cutting and dimensional inaccuracies. Another check identifies excessive countersink depths that may deform the opposite face and weaken the surrounding material.
Excessive countersink depth issue (sheet metal)
For CNC machining, the new undercut issue check detects recessed or overhanging regions inaccessible to standard tools, so designers can anticipate requirements for multi-axis machining, part reorientation, or postprocessing to improve manufacturability.
Drawing API and visual style updates in web
In the new release, the Drawing API has been introduced, allowing users to import drawings from the .mtkweb format. Also, 3D visual style enhancements include improved rendering of translucent materials and wireframe objects, updated default lighting, and added model shadows, along with a new default physical material for model rendering.
Read more about the changes in this blog.
About text formats
