NewTek Introduces RVD Series Hall Effect Angle Sensors
Noncontact sensors measure rotational position without mechanical moving parts that can wear out over time
Wed, 08/06/2025 - 12:01
(NewTek: Pennsauken, NJ) -- NewTek Sensor Solutions has launched its RVD Series Hall Effect Angle Sensors designed to meet the high demands of industrial environments where precision, reliability, and durability are critical. Using Hall Effect technology, these sensors provide exceptional rotational position (angle) measurement, offering high performance and dependability in the harshest conditions.
The noncontact design of these sensors measures rotational position without mechanical moving parts that can wear out over time. This unique feature extends the angle sensor’s operational life and ensures long-term measurement stability. In industrial settings where sensor downtime can be costly, this durability translates into long-term cost savings.
The noncontact measurement also enhances noise immunity, allowing for accurate measurements in environments with significant electrical magnetic interference. The RVD series provides excellent repeatability for consistent performance and operates in dusty, wet, or oily environments. This makes these sensors ideal for use in machinery, engines, and other demanding environments.
These rugged sensors can withstand a variety of harsh conditions, including extreme temperatures, vibration, and moisture. They offer a fast response time, making them suitable for dynamic motion applications. Their reliability and robustness make them ideal for various sectors, including automotive, industrial, aerospace, and energy, where they can be used for measuring angles in applications such as:
• Actuator feedback
• Valve actuation and gear monitoring
• Robotic joint and arm movement
• Shaft rotation for motorized systems
• Valve position monitoring
• Motorized actuator feedback
• Automotive steering angle
The sensors operate over a wide temperature range of -30°C–80°C, exhibiting excellent linearity of +0.3% of full range output. These angle sensors are also tolerant to shock and vibration. Their small size and versatile mounting options allow for easy integration into tight or complex mechanical designs, while digital output provides for an easy interface with microcontrollers, PLCs, and embedded systems.
The RVD Series Hall Effect Angle Sensors combine cutting-edge technology with practical design, ensuring optimal performance in demanding industrial environments.
For more information, visit https://www.newteksensors.com/lvdt-sensors/rvd-series-dc-rotary-position-sensor/ or contact sales@newteksensors.com.
