ForTest Provides Full Range of Quality Inspections
All products get leak and flow tests
Wed, 06/12/2024 - 12:00
(ForTest: Modena, Italy) -- Products that must prevent penetration of moisture or liquids undergo leak tests during manufacturing at the end of the production line. It’s not a sample test. Each product is 100% tested at the end of the line.
ForTest, a manufacturer of leak testers and flow testers, has more than 30 years of experience in industrial leak testing and flow measurement in the production line. With a wide range of leak test and flow test instruments, users can find the solution for every testing requirement.
The use of compressed air as a testing medium is widespread. This makes it possible to test the tightness of different types of products using different test methods (e.g., products that can be filled directly, or airtight products such as radio keys or sensors). Sometimes the leak test is combined with function tests (prefilling, valve opening and closing points, burst point). Product volumes to be tested range from a few ml to thousands of liters.
