Control Concepts Launches New and Reengineered AirSweep MAX
Patented pneumatic flow aid system provides 52% increase in performance compared to its predecessor
Mon, 05/27/2024 - 12:00
(Control Concepts: Chanhassen, MN) -- Control Concepts announces the AirSweep MAX, a globally patented pneumatic flow aid system that eliminates bridging, rat-holing, and buildup in bulk-material handling equipment in industries such as food, pharmaceutical, mining, and even in current recycling streams.
The AirSweep MAX (short for material activation excellence) improves on the performance of its predecessor, AirSweep, which is already installed in half of the S&P 500 companies and thousands of SMEs worldwide.
New global patents
The new AirSweep MAX uses aerospace-grade design specs and has 20 patented improvements and six proprietary parts. The AirSweep MAX is available in the VA-51 model and is ideal for bins, silos, hoppers, chutes, mixers, and other material handling equipment. Its improved performance shortens equipment cleaning time, which reduces downtime and increases available production time.
More power and productivity with less energy
Laboratory tests proved that AirSweep MAX delivers 52% more output pressure and 31% more air output than the original AirSweep.
